SpyderLovers Ambassador
Spyder Tire Pressure (auto-tire)
Tire Shops for Automobiles tires will do what they know for Car tires. Soooooo
that is exactly what they did. Check Spyder Forum for better help on Car Tire Pressures for Spyders.
That my Tip to You. .......
ENJOY YOUR LIFE WITH A SPYDER
Originally Posted by ARtraveler
18 for the fronts and 28 for the rear seems to be what "most" are using for tire pressure.
For KENDA tires .... He has Auto tires ..... just sayin .... Mike
Both Peter and I both recommend 15-17 front ( 17 for aggressive riding ) & 18-19 for rear .... We are both schooled in tire use ..... Mike
Everyone has their preference mine is 18 front 28 rear. has worked good for me and no unnecessary tire wear. Just my 2 cents.
Cruzr Joe
Cruzr Joe
For non-Kenda car tires, right?
28 PSI in a rear car tire? 20 PSI in my rear car tire makes for a slightly skittish ride..
2022 RT Sea To Sky
Baron, hopefully they got you resolved.
For comparison, in our 2014 RTS, I found 20 psi in the fronts worked best with our Federal Formoza fronts. We run a Yokohama s.Drive rear with 20 in that.
If you still have issues, as time permits, if needed you are welcome to have them balanced here.
I've got the stock Kenda tires on my 2021 RT, and initially put 22 front and 32 rear, just because I generally kept motorcycles at a bit higher pressure than normally recommended. After trying 18/28 as well, I think I have settled on 20/30 now. Easy to remember and gives a slightly firm ride which I like.
2021 Spyder RT
2023 Royal Enfield Hunter 350
Retired U.S. Army
Life Member, NRA
