Results 1 to 11 of 11
    Mar 2020
    Prior Lake, MN.
    Default Finally pulled the trigger on F3 - can I pull the same trailer my GW pulled??
    Hi fellow Spyder friends. Today I bought my first Spyder, a beautiful 2015 F3s with 10k miles on it.
    I have pulled a small camper trailer with my Goldwing for many years with no issues, can I pull this same trailer with my F3 without any concerns? Loaded trailer goes about 250lbs.
    Kind Regards Willie…….
    Aug 2015
    central oregon
    It will pull it ok but the hitch placement on the Spyder is tough on trailers. The hitch being attached basically to the rear wheel transfers any and all motion to the trailer. Make sure the trailer tongue is in good shape and if you have a cooler on it don't put and glass bottles in it.
    Oct 2011
    Kalamazoo, Mi
    WillieB Your F3 will pull the trailer just fine IF you can find a hitch that works for the S model. Currently, my understanding is, hitches are only available for the F3-T and LTD.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Aug 2008
    MA & NH
    Quote Originally Posted by fjray View Post
    Make sure the trailer tongue is in good shape and if you have a cooler on it don't put any glass bottles in it.
    Don't ask how I know.
    Bossier LoUiSiAna
    Probably need aftermarket hitch/harness; just watch the tongue weight- keep under 40#. As mentioned above the swing arm transfers all bounce to the tongue, not horrible, just be aware. After “13 most have 4pin square for trailer connector -might look for adapter while shopping.
    Mar 2020
    Prior Lake, MN.
    Thank You! I currently have a swivel hitch on the trailer, might go back to non swiveling hitch.
    Oct 2013
    Wood Village OR
    The reply about the tongue of the trailer taking a beating is correct. Both my wife and I pull trailers with our RTLs first with the 998s and now we have 2021s. I used to have a Aspen classic pop up that weighed 460 with all our gear and we never had problems towing or stopping. I have changed to a Lee-sure lite that weighs 325 and by the time I add some gear will put it closer to 375. I will be changing the tongue out with a shock mounted tongue to take up some of the beating they get from the axle mounted hitch. we have over 100k miles pulling trailers with the Spyders and are planning on riding to Alaska this coming summer camping the entire trip and plan on taking at least two months.
    2014 RTL , Black Currant
    Aug 2015
    NW Iowa
    I put this on my 2015 F3S. worked like a charm for a lot of miles. https://www.canamspyderaccessories.c...plug-and-play/
    Now
    2021 Sea2Sky
    Former
    2015 F3-S
    INDIANA, USA
    Default Alaska Trip
    Quote Originally Posted by easysuper View Post
    I look forward to hearing about your progress on your Alaska Trip in 2022. Good Luck and Good Health to you guys. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Durham,Maine
    I would love to stow away with you!!!! That will be such a great trip, and what a way to see the state, I have been there a few years ago and loved it, and said if I was going to do it again, camping would be fun to do!! Good Luck, be safe!!!!
    2012 RTL , Pearl
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    Easysuper Who makes that shock mounted tongue?
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
