Results 1 to 17 of 17
    Active Member wyo85's Avatar
    Aug 2021
    Wyoming
    Default What do you do when you have a flat tire on a ride?
    What do you do when you have a flat tire on a ride , here in Wyoming you are at 50 miles or more to the nearest town . ( plug it ? )
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    That's what i would do.
    Happily, I have never had the issue. I was 20 years in Alaska, towns and repairs very scarce. I never drive with bad tires. Have never been past the warning bars. Am partly disabled, so I cannot do any fixes. Tow truck or good Samaritin time. 175K Spyder miles.
    Mar 2015
    forrest above Reno, Nv
    Carry a plug kit and hope it's a front tire. But AAA is always there.
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2016
    Chillicothe, Oh.
    Good old fashioned string plugs with rubber cement, NEVER had any luck with the rubber plugs. A small air compressor of which many are available. Some like the CO2 cartridges, but once they are empty you are done. I prefer the compressor. All of this is available in small packages and easily carried on a bike. If physically unable to do a repair yourself have the kit onboard anyway. I always stop when I see a bike by the side of the road and ask if they are OK. If one of us has the required items I will gladly patch your tire as will many riders. It's what we riders do for each other.
    2015 RT , Black
    Sep 2021
    NY or FL
    Me ,too. I acquired a small Slime compressor and a "rope" kit. Don't leave home without them. Hopefully,I will never need them but someone else may and it will be handy.Makes me just a bit more comfortable knowing they are in a bag!!
    Sep 2020
    Middletown, NJ
    I carry a plug kit, 12v compressor, and a battery jump pack with my 'road tools' all the time. I've never needed the plugs but others have needed my compressor or jump pack.
    2020 RT base , Chalk White
    Aug 2015
    central oregon
    I have three bikes and each one has its own plug kit and compressor. That way I can't forget to switch units from bike to bike.
    Jul 2010
    Las Vegas, NV
    I am a nail magnet! I have plugs, glue, a compressor, tools. I’ve done plugs in NV, TX, AZ, NC, OK, MO(parking lot at Spyderfest!), and others, I’m sure. Nothing to it. The worst one, on the rest area parking lot, where a cattle hauling truck was parked upwind! The odor was beyond magnificent!
    99.9% of the time, the plug gets it done. Carry a kit, you are all set!
    Joe Meyer
    Feb 2012
    Spring City,Utah
    I have patched or replaced tubes for as long they had tube type tires so I always carry a patch kit, ropes glue and a compressor. Never needed them since we went to tubeless tires,but I have them just in case.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member hut1's Avatar
    Sep 2009
    Greenwood, DE
    +1 on the plug kit. Leaving work one evening I ran over a bungee cord hook when on my Goldwing, 90 miles from home. The kit and my onboard compressor was a life saver.
    Skip H.
    '21 Can Am Spyder F3 S
    '97 Honda Goldwing w/Hannigan Astro 2+2 sidecar
    [img]
    INDIANA, USA
    Default Spyder Flat Tire
    Only had one flat. I called AAA and they said it would be a 2 hour wait minimum....
    Only thing I could do was to wait. It was forever and 2 hours later. It's like they know how long they have till you get a second option. My second option was about 3 hours.
    Live and Learn. ........
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2021
    Netherlands
    Newbe question - not for a Spyder but Ryker though should not make a difference I guess. What type of onboard compressor are you talking about. Am trying to get a toolkit put together before the Ryker gets delivered in 2022 (have a stepless ratcheting tool (LaMonster), battery tender & will get a plug kit when bike gets delivered). Never thought of using a compressor instead of cartridges. And if you have any other toolkit advise... I gladly hear it.
    Clinton, MS
    Quote Originally Posted by Inge View Post
    The one I like best. Also use their plug kit.
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    I'm a retired Mechanic , and I learned many years ago , no matter what you know , or how many times you have done it before , nobody can repair or fix anything unless they have the right tools & parts . and I have several Cars , Trucks , and 2 Motor Cycles , and each of them has enough Tools and pieces to make a quick fix and most of the things that Might go wrong on the road . and I was so happy when the Tubeless Motor Cycle tires and wheels came out.
    Sep 2020
    Middletown, NJ
    This gets excellent reviews and many of my fellow riders use it.
    https://www.aerostich.com/aerostich-...ompressor.html
    Aug 2021
    Netherlands
    Brilliant - will see if I can get any of these in the EU.
