Results 1 to 7 of 7
    Aug 2019
    Stoughton, WI
    Default Wrapmyspyder vinyl install ?
    OK .. I'm pondering getting some wrapmyspyder frunk stripe/knee panel pieces to change up the look of my F3-S . The install videos make install look quite easy. Is it really that easy? Thanks
    2022 RT Sea To Sky
    Mar 2010
    Indianapolis, IN
    Smile
    I have installed several items from Wrapmyspyder over the years and it is not difficult. The key is to follow the install directions to the letter to get a professional looking result.
    Clinton, MS
    I think the hardest part might be getting the surface prep right so that it is smooth and has no residual wax buildup. Don't want the new design to go flying off.
    Aug 2018
    north wis
    Not hard but not the easiest thing you have ever done.Take your time and follow directions and you will be very happy with the results!!Make sure they are where you want them before you start sticking them down.
    Active Member hut1's Avatar
    Sep 2009
    Greenwood, DE
    , it's not too hard, especially with a couple of extra hands to help you. As with most things, planning and preparation are key. Just take your time.
    Skip H.
    '21 Can Am Spyder F3 S
    '97 Honda Goldwing w/Hannigan Astro 2+2 sidecar
    [img]
    Dec 2015
    Oakley Utah
    Yes, I think so. I'm all thumbs but did it okay. Watch and follow the steps in their video.
    2014 RTL Platinum
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Not quite hard, but make sure, you clean the surface with alcohol, to get the sticky part to stick... place them with the backing still on, postionthem with some adhesive (painters) tape, peel of half the backing, and just use common sense.
    Nowadays the stickers are very forgiving, and use a heat gun (moderate heat), to crimp the vinyl, when you are happy with the result.
    Looking forward to see the end result, I have the carbon kneepads from wrapmyspyder, and they fit, and look awesome
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
