Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
  1. #26
    Jun 2019
    Deltona FL
    Nope, just loosen the belt.....
  2. #27
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    spyderman loosen the belt from the adjusters?
    richie spyder
  3. #28
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by ssmcclub View Post
    to get the belt off the front damage red dust gear ,do I have to remove the bottom shock bolt and jack up the rear wheel?
    With the park brake on, remove the front pulley bolt. Then release brake.
    Raise rear wheel off the floor just enough so you can rotate it.
    While rotating it by hand, walk the belt off the rear pulley.
    Remove front pulley.
    Reverse process to reassemble.
