Results 1 to 25 of 32
    Active Member Beanz1's Avatar
    Aug 2021
    Louisville,KY.
    Default How do you know when your tank is low on fuel?
    To tell the truth i'm guessing when to add gas to my tank, because the gauge never change on my bike.
    Invalid Emails
    May 2021
    Ontario,New York
    My gauge works and so does my low fuel light.
    Active Member RykerRider1959's Avatar
    Jul 2021
    Wisconsin
    I dont push the issue...When the trip odo says ive ridden 140 miles its time to refuel...
    54 Snowmobiles...7 Dirtbikes...4 Atv's...8 Streetbikes...1 Tricycle...Since 1969...
    Aug 2021
    Louisville,KY.
    Quote Originally Posted by Pantera View Post
    How many miles do a full tank of gas your bike get if you don't mind me asking?
    Invalid Emails
    May 2021
    Ontario,New York
    I get between 165-170 miles before the low fuel light comes on.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Switch to autonomy mode. It shows how many miles to empty. That is the most accurate.
    May 2009
    Connecticut
    Quote Originally Posted by Markubis View Post
    Best way! I switch to Autonomy after I fill up on the way home a few miles from the house and I normally get 128-130 so I must Not be filling it all the way which is fine with me because All my afternoon rides are about 85-110 miles.
    Sea Doo GTI-SE 90 Jet Ski!!
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    You are very low when the engine sputters and/or dies, but don't test it! Running an FI dry is hard on things.
    1976 RD400c
    Active Member TIMEMACHINE's Avatar
    Feb 2021
    King George, VA
    That is no where near accurate.
    On the Ryker, the golden rule is set your trip meter and fuel up at 140 miles.
    Jan 2015
    Indianapolis, Indiana
    My fuel gauge works but shows full until I get about 75 to 85 miles on a full tank. After that the bars start going down. I usually try to fuel up around 125 to 130 miles just to be safe. Like some of the others I reset the trip meter at each fill up.
    Durham,Maine
    Quote Originally Posted by Beanz1 View Post
    If you ride a lot of local stuff, play with it and set your trip meter and ride it until the light comes on, check the mileage and go gas it up! Then you can use that as your set point and know when you have to start hunting down a gas station on a long cruise!! Good luck!
    2012 RTL , Pearl
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    ...There's a light ?..
    Miles to empty depends a lot on how full you get the tank. It's difficult to get the tank truly full. But on long trips, it's worth the extra effort.
    Jan 2018
    NH
    Quote Originally Posted by TIMEMACHINE View Post
    I only said it was the MOST accurate. Your method requires making sure the tank is truly topped off, which requires pulling the nozzle out until gas almost spills out of the tank. Then the trip odometer needs to be reset as well. Many people don't want the hassle. They want to gas and go.
    The autonomy setting has reliably shown when the tank is getting low. When it shows 20 to 30 miles left, fill the tank.
    May 2021
    Long Island, NY
    Quote Originally Posted by RykerRider1959 View Post
    Same thing my wife does with hers.
    2020 600 ACE , Black/Red
    Aug 2021
    Louisville,KY.
    Thanks will do.
    Aug 2021
    Louisville,KY.
    Thanks all members.
    " don't want the HASSLE " ..... those folks should get a chauffer to make life easier ...... Mike
    Miles to empty ......a lot on how full you get the tank. It's difficult to get the tank truly full. But on long trips, it's worth the extra effort.
    " difficult " ???? .... 10 seconds worth of effort at the most .... I wouldn't call that Difficult, those type of people REALLY miss the gas attendants .......JMHO ..... MIke
    Jan 2018
    NH
    Have you ever put gas in a Ryker or are you basing your answer on your Spyder experience?
    Durham,Maine
    I reset the trip at every fill up!!
    2012 RTL , Pearl
    Dec 2018
    NY
    I reset the trip at every fill-up and use the autonomy setting
    Full tank is about 185 miles or slightly less depending on driving style. Low fuel indicator comes on when autonomy reports 34 miles to go.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Active Member KnurledNut's Avatar
    Jul 2021
    Favoretta, FL
    I keep an eye on the gauge and distance remaining. When the fuel bars start dropping and reach the midpoint, the distance is approx. 70ish miles. Time to fill the beast with pure unleaded petroleum. No ethanol for my lady.
    2021 , generic
    Ohio
    Can someone explain the issue with just using the fuel gauge on the bike? When I fill up the gauge indicates approximately 277 miles and I have ridden it down to 60 to 70 miles before fill-up. Now I’m not sure if this is actual miles or an estimate based on how hard the engine is running. Would the bike run out of fuel with miles still indicated on the gauge?
    Poasttown
    2019 F3L
    Invalid Emails
    May 2021
    Ontario,New York
    Quote Originally Posted by Poasttown View Post
    Poasttown
    2019 F3L
    There really is no issue with using the fuel gauge on the bike.The gauge just moves slowly from the full mark and drops rather quickly from the half mark down.It does show when you are low on fuel and the low fuel light works correctly.
