Results 1 to 17 of 17
    Jul 2021
    Ontario
    Default Turn signal dash light hyperflashes, rear light doesn't work - 2015 RT-S - Any Ideas?
    I have a 2015 Spyder RT S. The right rear turn signal light has stopped working. I have done the following:
    Installed a new bulb - problem not solved.
    Installed the defective bulb on the left rear side and it worked; clearly the bulb is not the problem.
    Switched the right rear cluster of lights to the left side of the bike and every light worked! Switched the left rear cluster of lights to the right side of the bike and the turn signal light did not work; clearly the light clusters and the wiring within them are not the problem.
    Tried Lamonsters technique of holding down the hazard light button for 30 seconds then turning it off, etc did not solve the problem. It did however correct the hyper flash I was seeing on the front instrument cluster when I pressed the right turn signal switch.
    Turning on the hazard lights results in 3 out of 4 flashing; the right rear one not working.
    I have checked for voltage at both rear turn signal sockets and I get between 6 and 12 volts, as per spec.
    I am now at wits end; does anyone have any bright ideas, pun intended? Your help is always appreciated.
    Oct 2015
    Lynden, WA
    Have you checked that the right rear bulb socket (Brass part) has a good ground?
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Bossier LoUiSiAna
    have had a trailer hitch harness mess mine up. Just the Right Rear. Took a min to find but with rest of blinkers working that was only item mid stream. Some diode in harness not the module.
    Jul 2021
    Ontario
    Quote Originally Posted by Haze View Post
    Thank you for your input!
    Ground appears good. Furthermore, the whole right rear light assembly (brake lights, turn signal light and reverse light) was plugged into the harness on the left side of the bike and every light worked. This suggests that there is no fault with any of the socket connections.
    Jul 2021
    Ontario
    Thank you for the input!
    Where would I find this diode and what does it look like (I am better at understanding mechanical rather than electrical issues)?
    Bossier LoUiSiAna
    Quote Originally Posted by Scarlet View Post
    First off: Do you have a hitch & harness installed? sorry Have not found replacement diode As of yet, might be BRP special. However harness will be under seat & most rear panels. Varies per models
    Jul 2021
    Ontario
    I do not have a hitch and harness installed. Sounds like I will have to remove some additional body panels to access the wiring harness. Any thoughts as to whether it may be the turn signal switch in the handlebar cluster?
    Bossier LoUiSiAna
    If is only the rear blinker it is a connection in the middle somewhere No trailer harness should be easier to track.
    Oct 2011
    Kalamazoo, Mi
    This also suggest that the handle bar switch is functional. ( I am assuming that when you plugged the right side wiring harness that you switched the switch to the right) That will be the eextent of my contributions.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Jul 2021
    Ontario
    Right rear turn signal not working.
    When pressing the right turn signal button, the dash turn signal lights hyper flash and the rear flasher does not come on. I managed to get rid of the hyper flash and when I turned on the ignition and pressed the right turn signal button everything worked fine… for 5 seconds. The right rear turn signal bulb started to dim and after 5 seconds or so, it was out, and the hyper flash issue resumed.
    Any ideas what might be causing this?
    Last edited by Peter Aawen; 04-02-2024 at 12:31 PM. Reason: Removed Post title after thread merge into existing thread - they mess with Searching! ;-)
    Oct 2020
    Arizona
    Put a new bulb it!
    Quote Originally Posted by Snoking1127 View Post
    Put a new bulb it!
    I think that bulb has not quite failed yet but is going to soon .... The Hyper-flash on the dash is very similar to that of auto systems, in that they let you know the bulb is out .... Mike
    Sep 2016
    Chillicothe, Oh.
    Here's three votes for a new bulb.
    2015 RT , Black
    Jul 2021
    Ontario
    Put a new bulb it!
    Putting in a new bulb was the very first thing I did - no change! I switched out the ‘supposed defective bulb’ for the left rear bulb and same issue on the right side. The ‘supposed defective bulb’ works fine on the left side rear of bike. This tells me that the bulb is not the problem. I even went as far as switching the two rear light clusters. The problem persists which tells me the light cluster is not the problem.
    Could this be a wiring issue somewhere between the right rear light cluster and the turn signal light on the dash?
    Last edited by Peter Aawen; 04-02-2024 at 12:24 PM. Reason: Removed Post title - they mess with Searching! ;-)
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    New LED bulb where it was a halogen or other type bulb before? Might be it needs a resistor.
    2021 RT Base - Petrol Blue
    Jul 2021
    Ontario
    Quote Originally Posted by Quickdraw View Post
    Original bulb was OEM halogen type and new one is the same. All the lights on the bike are OEM. Someone suggested to me to check the wiring harness ground connections. Except for the negative terminal on the battery itself, does anyone know where there might be additional ground terminals on the frame or engine block? Perhaps one might be loose or corroded.
    Durham,Maine
    Put a meter on the bulb socket see if you have juice.
    2012 RTL , Pearl
