Results 1 to 14 of 14
    Feb 2020
    Ontario, Canada
    Default 2019 F3-T Markings on Drive Belt
    My wife rides the F3-T has the vibration at highway speeds, does not have a belt tensioner. I will be ordering the Lamonster Belt tensioner assembly and the Krikit II belt tensioner tool
    There are markings on the top side of the belt - see photos. These markings may have been left by a stone?? Nothing in the belt covers...something I need to be wary of? the marks are superficial, dont feel them with a finger nail.
    Comments?
    2020 RT , Lamonster Brake Pedal Riser Petrol Metallic
    Feb 2019
    Portland, Oregon
    Before you order the tensioner, get the Krikit II and adjust the belt to 140 rear wheel off the floor, 160 on the floor. The factory and shops set the belt too tight. I think, after doing that, you may have little or no belt vibes. Also, there should be a gap between it and the flange the thickness of a credit card.
    Feb 2020
    Ontario, Canada
    Thanks , have the Kritit on order will definitely check belt tension
    Is the 140 the correct spec? have seen as high as 160 being suggested
    Craig
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by cdavis6 View Post
    Craig
    That is what others on this forum recommended, so I tried it. I get a wee vibration at around 72 mph, but I can ride around that. I do not want to put a tensioner on my bike.
    Craig
    with ... RICZ ... I ( and lots of others ) measure the tension " wheel on the ground ".... the 160 lb. is equal to the 140 lb. when the wheel is OFF the ground .... Get the tensioner if you feel it's necessary, I don't have one - Why because they break and can TRASH your $350.00+ drive belt. I have little or no vibes. It's a motorcycle not a Rolls Royce. ....JMHO .... good luck ..... Mike
    Sep 2016
    Chillicothe, Oh.
    Results can vary as well. I had to take my tension to 180 on the ground to find my sweet spot. I have had my 2015 RT up to 90mph with no vibes. I had a well made tensioner from a vendor that's no longer in business and it lasted 10,000 miles before going bad. I put more than that on in a season so the tensioner didn't get me through a year. No more tensioners for me.
    2015 RT , Black
    There are markings on the top side of the belt - see photos. These markings may have been left by a stone?? Nothing in the belt covers...something I need to be wary of? the marks are superficial, dont feel them with a finger nail.....
    If you can't see/find anything that the belt is actively rubbing on as you ryde, then those marks are probably just from road grime, rain, mud spots, whatever, and because they are superficial, can basically be ignored! . You should see what the top side of my RT's belt looks like after I've done a few hundred miles of gravel/dirt/mud/sand; but no matter how dirty it gets afterwards, it hasn't had any issues yet, and it does more gravel/dirt/mud/sand miles each year than most Spyders do in their entire life!!
    And before anyone asks - Yes, I do inspect it fairly often (& clean the caked on mud & marks off it! ); No, I haven't ever had any real belt issues; Yes, it is still the Original belt that the Factory put on back in 2013; and NO, I don't have any extra belt guards!
    Durham,Maine
    Ride more, worry less!!!! Keep it stupid simple!!!
    2012 RTL , Pearl
    May 2013
    Apex, N.C.
    Wow, I wasn't aware that the tensioner was a problem. I just replaced my belt, with the whole intention of doing so because I wanted to add a tensioner, and my current belt had a stone in it. But if the tensioners are giving problems around the 10k mile mark, then I will do without. I don't have a lot of vibration, but thought it would be worth checking into. Thanks for the information.
    Sep 2016
    Chillicothe, Oh.
    My issue was at 10,000 miles (I checked it around every 2000) the bearings in the roller were starting to fail. If one of these things lock up the potential for belt damage is high. I chose to experiment with various belt tensions and get rid of the tensioner (dampner actually) I don't care who manufactures these dampners you need to inspect them on a regular basis. These gadgets spin at a high rate of speed in a very hot and dirty environment and eventually the bearings will fail. If you ride a lot of miles in a season I think I would pass on a dampner. If your Spyder is just butt jewelry that you ride 1000 miles a year then probably no issues will occur for a long time.
    2015 RT , Black
    Feb 2020
    Ontario, Canada
    Thanks everyone!!
    Seems like a lot of different views out there (going by this post as well as other posts)
    I truly do appreciate all comments, seeing as this is my wife's ride that exhibits the vibe, I want to be sure to do it correct so it doesn't leave her on the side of the road.
    I will do this in stages, first the tension check and set (as needed...duly noted on spec 160 on the ground 140 in the air).
    I will post up my findings,
    Thanks everyone,
    Mar 2017
    I have an idler and replaced the roller with Lamonster's roller. Luv it. No vibes, nice ride.
    https://www.lamonstergarage.com/can-...ley-lamonster/
    Let me clarify ..... Not ALL tensioners are going to fail .... however I have read on this site, quite a few have ..... I' learned a long time ago " trying to achieve Perfection can be a Big mistake " .... I have very low to no Vibes ..... Another issue ( as to Belt tension ) that I have learned ( here ) is the possibility that BRP's Higher Belt tension specs may be the reason for " drive pulley failure " ( I have no red dust ) ..... I recommend that you lower the belt tension and see what happens..... Lower tension is not going to cause any issues that I have ever heard of ..... good luck .... Mike
    Durham,Maine
    For every one that thinks these bike vibrate, I wish I could have taken you for a ride on my dad's 60's ElectroGlide, man that thing was so bad that the foot pegs would tickle my feet to the point you would have to use your heels instead of the arch of your foot, at any speed!! To me if my bike was that way, I would say there is a problem that needs to be looked at, a small vibration at 75 mph, call it your warning light that your flux capacitor is about to kick in and take you to a different time zone!!! Keep it simple!!!
    2012 RTL , Pearl
