Results 1 to 17 of 17
    Default BRP Trailer Hitch - Plastic Shims
    I have been following this thread about the OEM plastic wear shims on the trailer hitch since I've gotten a few calls recently about a replacement kit.
    https://www.spyderlovers.com/forums/...-is-this-right
    As far as I know, there is no 'Replacement Kit' for these. Strange being that they are a wear part. I know that some have found other DIY methods of taking care of this. But I am wondering if there is much interest in a Plug & Play set. I am hoping to get material that will allow me to offer a lifetime warranty on them. I am working on this now.
    Mar 2019
    NEBRASKA
    Spoke with both BRP and local dealer and no luck with this endeavor on shims....thank you Ron!
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Quote Originally Posted by davev1pa View Post
    My Can-Am dealer is saying the same thing. Very odd. But it may indicate that there just isn't much call for this item. Still, I am going to make a few sets and see if I can get some Test Pilots to run then and see where it goes.
    Thanks for the input!
    SoFlo
    FWIW, those are not actually a wear item per say. Functionally they protect the painted surfaces from scratching. There is no movement to create true wear. If they are missing, the bond adhesive failed and the pads simply fell off.
    I was thinking the same thing. But my dealer was really no help. People call them a 'Wear Item', and the set I have looks like it's been rubbing. But I don't really see how they would wear out. I suppose they come out while traveling? Still, I'm not sure why you can't purchase a set from BRP. But it appears that your only choices right now are to purchase the entire hitch, or make them yourself. Not sure it's a product that many would want. But it won't take all that much for me to get a few made.
    Sep 2014
    USA
    I think it also helps slide the hitch arm on the mount.
    Well, you certainly do not want steel on steel. This is probably the main purpose.
    Sep 2014
    USA
    If it was designed diffently you wouldn't need them at all.
    Jul 2010
    Las Vegas, NV
    Htpe 3/16”. Cut rectangles. Works perfect. I get mine from welsh plastics in Las Vegas. Joe
    Joe Meyer
    SoFlo
    Took a few minutes to do a preliminary drawing in AutoCad of these shim pads. Dimension were based off pencil rubs from a member here. Should be very close, but have not yet verified them as 100% accurate to those installed on our hitch.
    Material thickness measured as 1/16" by the provider of the pencil rubs, but should be verified also.
    Very simple part to produce by hand or on automated equipment. Automated would be maybe 1 minute to cut all 6 shims from the very inexpensive sheet thermoplastic material.
    Mar 2019
    NEBRASKA
    Measured shim with calipers it is .068 inch or 1/16th or 1.73 mm likely made as 2mm as these were measured with used shims ..
    Mar 2013
    Maumelle, AR
    Look for "Hitch Slides" and the BRP part numbers are:
    Upper RH 705202352
    Lower RH 705203216
    Upper LH 705202351
    Lower LH 705202350
    2020 RT Limited , Chalk
    Mar 2019
    NEBRASKA
    Hi C-man!! I tried to search those part #s you've posted to no avail....but I'll call BRP and the dealer tomorrow with those #s and see whats shaking...Thanks for the info!! Dave
    Mar 2019
    NEBRASKA
    I called the dealer and checked with BRP instructions and unfortunately these are not active part #s
    Mar 2013
    Maumelle, AR
    Try here:
    http://www.adeptpowersports.com/
    Upper RH 705202352
    Lower RH 705203216
    Upper LH 705202351
    Lower LH 705202350
    http://www.adeptpowersports.com/oem-...2351-part.html
    Mar 2019
    NEBRASKA
    Went to Adeptpowersports and yes those part #'s are showing but to the right it reveals that they no longer support or stock can am items. When using those part #s my BRP dealer states he cannot cross reference "unusable" previous #s....OMG so ridiculous....thank you for ur diligence!! Also when i go to https://instructions.brp.com/e-instruction.html#tab=1 i cannot enter those part #s with any success
    Sep 2014
    USA
    I found out awhile back when trying to locate a harness for the heated seat. I could find the part number but BRP does not sell it.
    Sounds like the same for your hitch shims.
    Locate some UHWM plastic stock and cut what you need.
