Results 1 to 3 of 3
    Apr 2015
    tampa
    Default What is the correct Oil plug size??
    Found info..disregard..
    What is the correct size for right side oil drain plug on 21 RTL spyder.
    Mine stripped.
    May 2016
    Mansfield, Ohio
    Just did the 3000 oil change on our new '21 RTL. Not impressed with Rotax and their crazy drain plugs. 6mm hex on the RH side and Torx #45 on the LH plug!! And the transmission filter is integrated into the RH engine clutch cover so you have to replace the entire $100+ cover every 28,000 miles. C'mon man!!
    2021 RT Limited , Deep Marsala Metallic (red)
    Get your HCM filter from Bajaron. Clutch Cover drain plug is M12x1.5 get the copper washer too, PN420250640.
