Results 26 to 50 of 61
  1. #26
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    I still wear the same gear that I wore on 2 wheels... tourmaster boots now, riding pants on tours and jeans when not, textile jacket, helmet and gloves when not too beastly hot. I went down 4 years ago and besides a broken leg/ankle (boot didn't save that) I had no road rash. Getting cut off on a harley is not fun I learned Rub some dirt on it and keep riding!
  2. #27
    Mar 2021
    Arizona high country
    I am actually thinking of installing a hand operated brake lever, just so I can quickly operate the brakes while getting my foot on the pedal.
    That is a good option, but you might try the Lamonster brake rod first. Solved that problem for me. But agree a handbrake would be nice, but expensive.
  3. #28
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    Tennis shoes. If they were good enough for Jax Teller...
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
  4. #29
    Apr 2020
    tucson az
    I wear over the ankle boots or hikers. At work they poke fun of my shoes because most to the people I work with wear tennis shoes.
    2011 rt , pearl white
  5. #30
    Clinton, MS
    Where's all the flip flop fans I always hear about but hardly ever see?
  6. #31
    Harrington, Australia
    Quote Originally Posted by rjinaz86323 View Post
    I’d love to use Lamonster’s shortened brake rod rjinaz….indeed, I had one on my F3 ………unfortunately, the ‘21RT doesn’t use a brake rod, and you can’t “clock” the brake lever position lower as BRP have doctored the spline to prevent it
    HeliBars Handlebars
    Ikon (Aussie) shocks all round, with sag adjusted for extra 3/8” clearance up front
    Kenda Kanine rear.
  7. #32
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    One of them was in the hospital bed beside me when I last came off and broke a few things. Only one of us was able to return to riding.
  8. #33
    Apr 2021
    Bartlett, TN
    I have been wearing Cruiserworks boots for a very long time. Too bad they don't make them anymore because I would love a new pair. They saved my feet when I crashed my 2008 Nomad in the Ozarks back in 2015. I wear them in case I have an unfortunate superman event on the Spyder.
    2021 Spyder RT-L Deep Marsalsa Metalic
  9. #34
    500 CITY, INDIANA USA
    Default Boots
    I had always worn my work boots.
    But then times changed and now I wear my ankle boots.
    Thanks you and have a wonderful day. ....
    ENJOY YOUR TIME ON YOUR SPYDER
    Ryde with a Friend and Stay Safe.
  10. #35
    Inactive User
    Oct 2019
    Sweden
    I use motorbike boots, with a quite stiff sole and additional protection for the ankles.
    It is a trade off for comfort and ease for walking when off the bike, I've in the past used touring boots that go higher up on the shins and offer some protection against twisting of the foot as well, but they are less comfy and reduce the "feel" for the brake pedal.
  11. #36
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Yes. Presently Bilt boots from Cycle Gear. Pretty comfortable on my flat feet. Need to get the wife a pair as she is presently using my Tourmasters. We carry sneakers if we plan to do a lot of walking and change in/out of them there.
    1976 RD400c
  12. #37
    Active Member Luvs2Ride's Avatar
    Apr 2013
    Mechanicsburg, PA
    Default Boots
    Boots (left over from my 2-wheel days) for almost all rides...
    Ride Safe,
    Gina J
  13. #38
    Inactive User
    May 2013
    Sacrament0, CA
    I wore Alpinestars Gortex waterproofs for many years. Excellent boots for 2 wheels. Now I'm on the Spyder I wear Redwing Irish Setters, over the ankle style. Very comfortable boots.
  14. #39
    Mar 2021
    I recently bought a pair of these and am very happy with the comfort and the fit.
    Carhartt Men's CMX4023 Lightweight Casual Wedge, 4" Soft Moc Toe
  15. #40
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Here in CA, I have only ever seen flip flops on Japanese sport bikes, mostly in beach cities, usually on a rider wearing shorts and a tank top. Makes me cringe.
    I always wear at least ankle high boots. Since, like Pete, I wear either a 14XW or 15W depending on the manufacturer, my choice is generally Timberland or Dunham (New Balance).
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
  16. #41
    Mar 2021
    Haven, Ks
    I have seen several references to the LaMonster shortened brake rod for the F-3 and he shows it on his web site but no similar posting for a shortened brake rod for the 2019 and prior years RT. I have a 2019 RTL - SE6 and would like to lower the brake pedal on it. Unless I lift my foot to apply the brakes, if I try to lift at the ankle and pivot over to the pedal, I get a severe cramp in my leg and ankle. Will the F-3 shortened rod fit on the 2019 RT? I know it won't work on 2020 and newer but I have a 2019 which does have a brake rod. Just don't know if it is compatible with the RT.
  17. #42
    Jul 2021
    IL
    Quote Originally Posted by HayRog View Post
    There must be dozens of version of Redwing Irish Setters. Curious as to which one you wear.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
  18. #43
    Aug 2013
    I’m one of only three on this thread that wears sneakers. And shorts, but that wasn’t part of the question. Lol
  19. #44
    Apr 2017
    Temple, Ga
    Quote Originally Posted by SNOOPY View Post
    You can make it 4 wearing sneakers most of the time.
    2015 RTS , Black
  20. #45
    Aug 2020
    California
    yup, I sure do.
    Thunder's just the noise. Lightning does the work.
  21. #46
    Bartender, this is a thread about boots, and it would have a limited audience. I really would suggest you start a new thread with some kind of “shortened brake rod” heading if you want people to see/answer your question
    Quote Originally Posted by Bartender View Post
    HeliBars Handlebars
    Kenda Kanine rear.
  22. #47
    Jun 2021
    Bossier City, LA
    When I was on 2 wheels, I ALWAYS wore boots. Now that I'm on 3, not so much. It is actually hit or miss whether I wear my boots. I know I should wear them, but often wear sneakers because it's easy.
    I bought a pair of Rocky "Duty" boots a few years ago. I have been please with them, they have an aggressive sole, and they'll protect the ankle if the need arises.
    --Exco
  23. #48
    Inactive User
    May 2013
    Sacrament0, CA
    Quote Originally Posted by vito1943 View Post
    Irish Setter Ravine
  24. #49
    Mar 2013
    Marion, Arkansas
    Well here we go, another debate whether to wear boots when riding our Spyders. Haven't I seen this before with something to do about tires or oil Sorry to disappoint everybody but I wear tennis shoes when I ride my Spyder. Now I want to hear about how dangerous it is to ride without boots.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  25. #50
    I wear ankle high boots as a minimum in warm weather. They're required on military bases. In cold weather I have some insulated boots, also ankle high. My SIDI riding boots aren't as comfortable or easy to get on/off so I haven't been wearing those with the Spyder.
    Exactly the same experience with the SIDI boots. Almost 12 years old and still like new.
