Results 1 to 7 of 7
    Active Member motoguzziman's Avatar
    Jan 2021
    Oconomowoc, WI
    Default Pull behind trailer tire air pressure
    I bought a small pull behind two wheel trailer to pull behind my 2020RT. The trailer has a torsion (ie rubber) suspension and has 4.80 x8 tires. When I was replacing the lights I noticed a couple of stickers on the inside of the box which showed that the hitch weight should be 20-30 lbs and that the tire pressure should be 20 PSI. This sounds like a pretty low tire pressure but then again we will only have about 100 lbs max in the trailer. The soft tires would help smooth out the bouncing which is not bad. (Suspension is rated at 250#).
    If you have a similar trailer, what are you thoughts on the tire pressure. What tire pressure do you run?
    2020 RT , Chalk White
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    what does the manufacture of the trailer say the tire pressure should be?
    Do not go by the tire pressure rating on the tires, only go by what the trailer manufacture recommends.
    2022 RT Limited , Silver w/ Black and Purple accents
    Jan 2021
    Oconomowoc, WI
    Manufacturer is no longer in business. Not sure if sticker in the box is from the manufacturer or previous owners. Just interested in what others with similar trailers are running for air pressure in the tires
    Active Member Gldwnger's Avatar
    Apr 2015
    Kitts Hill, Ohio
    I run 18 to 22lbs in my Harbor Freight "TAG A LONG" trailer. (Basically a Sears cartop carrier on wheels). We usually carry from 100 to 200lbs of weight.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    I use 15 lb in my small utility trailer with a cartop box bolted to it. It has 8" wheels.
    Never had a problem with its tires when loaded with spyder clothing and stuff for 2 people.
    It also has torsion suspension for each wheel.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    15 pounds works well for me. The previous owner of the trailer ran 20# and the tires wore more in the center, and I think it rides better at 15#.
    2020 RT Limited , Petrol Blue
    Active Member Big Juice's Avatar
    Jul 2017
    Hot Springs Village, AR
    I use 23/25 #s, per the trailer manufacture, not what the tire says. No problems over several years of towing.
    O. J.
    Ridin' "Lucille", the MusicMaker
    a 2017 F3 Limited (Pure Magnesium Metallic)
    Wife, Jan, riding "Ruby Jane"
    a 2016 F3-T (Intense Red Pearl)
    2017 F3-Limited , Magnesium (light grey)
