Results 1 to 7 of 7
    Jun 2015
    Ritzville, Wa
    Default Anyone know what Error code P2304 means?
    Anyone know what this code means? Asking for a friend. He has a 2021 600...Search did not turn up anything.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Ignition Coil Primary Control Circuit high reading?? Faulty coil, harness, or poor electrical connection??
    https://www.engine-codes.com/p2304.html
    Durham,Maine
    Peter did you google that code or do you have a web site you go to?
    2012 RTL , Pearl
    That was just Google (well, DuckDuckGo actually! ) cos I couldn't find it on SpyderCodes.
    Aug 2020
    Germany
    Greg, i did a research in the service manual for Ryker 2019 and 2020 and could not find the fault code P2304 there.
    Maybe this code is only used since the model 2021, so it could only be found in the service manual for models 2021 ... but i dont think so.
    Could it be also possible, that there is some kind of confusion or misunderstanding and it is an other code (maybe the leading letter or one of the four numerals is different)?
    Can you check this out once more?
    Regards
    Michael
    Sep 2019
    illinois
    From reading Peters info at #2 I'd ask myself if I hooked up any aftermarket electronics recently and go from there.
    Jul 2022
    TX
    Quote Originally Posted by gkamer View Post
    Did u ever find out what was wrong with it. I got the same code this morning on my Ryker.
