Results 1 to 12 of 12
    Jun 2014
    NH
    Question Radio has poor reception & lots of static - anyone else?
    Just bought '21 RT Limited (2nd RT I've owned) noticed that I am getting a lot of radio static and stations fading in and out( like the signal is weak) on most stations. Brought it back to the dealer to have it checked out and he could find no problems. Always had strong signals on my old bike and I was wondering if anyone else is having this issue with the new bikes? Thanks in advance for any input!!
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Same on our new RTL. Guess I was spoiled by the radio (and all audio) on our '06 GoldWing.
    1976 RD400c
    Nov 2020
    Lincoln, Nebraska
    Forget the radio and plug in your phone to a USB port.
    Nov 2016
    Upstate NY
    yup. my 21 wont pick up any stations at all
    Active Member jredman's Avatar
    May 2013
    Caddo Mills, TX
    This may sound strange. I have had my 2020 Spyder RTL for over a year and have about 16k miles. Have never even turned on the radio or listened to music. Can't here it anyway going down the highway. Too distracting in the headset.
    Durham,Maine
    Some say that they have found a connection some where under the seat that they have found unplugged from the factory!! may want to poke around and find where the antenna plugs into the harness
    2012 RTL , Pearl
    May 2021
    PA
    Our 21 RTL made 2/21 had radio reception issues. On another thread I saw someone took there’s to a dealer and they found the radio antenna plug under the passenger seat unplugged. I checked ours. It was connected but not fully seated. I unplugged it and found the female side of the plug inside bent over. I used a dental pick and worked it back into shape. Plugged connection together with a locking snap. Reception is much improved now. Appears to have solved our reception issue.
    Aug 2012
    Central Ohio
    I pulled on the antenna on our 20 RT and it came out of the rubber boot. It had never been threaded into the connector. Probably another thing the dealer “forgot”. You might check that too.
    Jun 2014
    NH
    Thank you all for the good info..I'll be doing some checking
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I don't think it is limited to spyders. I have an Acura MDX I bought new and the reception is terrible. Of course Acura says nothing wrong. I listen to my music on my phone more now.
    Apr 2021
    Washington
    Quote Originally Posted by Kingz View Post
    I also had the antenna never been threaded into the boot issue on my 2021 sea to sky
    Mar 2021
    East TN
    Today, I pulled the topcase and left saddlebag plastic. Then pulled the antenna to discover it is 6mm x1 thread stud threaded into the mount. Went to O'Reilly and bought a 31" black, spiral wrapped antenna with assorted adapter studs. But it was 6mmx1 also, so I just cut the head off of a 6mm x 1 x 1" bolt, screwed it into the new antenna bottom and into the mount. Added a short piece of rubber tubing, a grommet, and some shrink wrap to keep water oug and make it look factory again. Stations now come in clear that I expect to, with much less noise and more volume. Plus, to handle my MP3 files, an old LG phone with non-provisioned SIM is now paired as BRPC's demanded phone. I can play my MP3s through it, and nog have the bike complaining when I want to change inputs.
    1976 RD400c
Tags for this Thread
