Results 1 to 25 of 25
    May 2021
    Tennessee
    Default Anyone installed BRP's RT-L arm rests on a 2021?
    Has anyone installed the BRP armrest on the 2021RTL, they are pricey but I just don't care for the Showchrome which is not available until mid sept.
    Sep 2018
    greensburg,pa
    I had them installed when I ordered mine last year. Wife loves them but they do not fold up just slightly outward. Worth the money over the older style from BRP.
    Have minimal adjustment for Hight and forward or back. MINIMAL with bolts so I had to let her ride on back and then remove the bolts for adjustment to were she was comfortable-she wish they were more forward.
    Pretty easy install but the instructions wont load from BRP!
    https://www.youtube.com/watch?v=IJRHRR6FLOw
    2018 RT-L , Blue
    Aug 2020
    California
    Installed them on my 2019 F3L. They are solid. The aftermarket rests I have seen are flimsy in comparison. You do have to give up the heated passenger handgrips - not a problem here in Southern California. The armrests themselves are a bit slippery, so I put some transparent anti-slip tape on them. My GF is very happy with the setup.
    Thunder's just the noise. Lightning does the work.
    Sep 2018
    greensburg,pa
    Quote Originally Posted by wmjweber45 View Post
    Passenger heated grips work fine on my 2021!
    2018 RT-L , Blue
    Jan 2021
    Oklahoma City
    Quote Originally Posted by bluewoo View Post
    Can we get a pic from the side that shows the heated grips and arm rest both, please. I thought the arm rest mounted in place of the grips...guess I was wrong! Maybe I'll see a 2020+ Spyder with the arm rest mounted at the Hot Springs Spyder Rally this week.
    May 2021
    Nevada
    Default arm rest
    I have installed the BRP arm rests on my 2021 S2S they are nice and as stated above solid with little adjustment, but there are after market plates you can get from Spyderpops, slingmods and the others that will give you a bit more height adjustment and forward/aft adjustment. The stock height was to low for my wife and she is pretty short, the plates put the armrest in just the right place for her. They do swing (pivot) out about 1 1/2" to 2" for egress off the seat and there is a spot on the forward bottom of each one to mount a four bolt ram mount ball for drink holder/phone/gopro or what ever. I mounted a 1" ball mount and 2" extension swivel and cup holder for the wife.
    Also they do not replace the grab bar, when mounted they sit over the grab bar and mount with a hook in back and a bolt in the front. You replace the plastic panel around the grab bar with the provided half panel. Takes 10 minutes or so to install both arms.
    2021 Sea to Sky , cyclops light, front fender light/turn signal, rear run/brake/ turn signal LED strip, BRP floor board light Green
    Sep 2018
    greensburg,pa
    Quote Originally Posted by Spiderfrog View Post
    Ill have to look into hose plates! Thanks
    2018 RT-L , Blue
    Sep 2018
    greensburg,pa
    Quote Originally Posted by Adventurer View Post
    2018 RT-L , Blue
    May 2021
    Nevada
    Aug 2016
    Pembroke, Massachusetts
    The difference is they don't both fit on the F3 but they both do fit on the 2020-21 RT.
    May 2021
    Nevada
    The arm rests are a nice addition for me, my passenger (wife) has a tendency to fall asleep on long rides even on my superglide she would fall asleep and I had to hold her against the back rest. On the spyder with armrest no issues. She can fall asleep and still be secure without me holding her on/in.
    Jan 2021
    Oklahoma City
    Thanks for the pics. Still hoping to see some in person at the Hot Springs rally
    Sep 2018
    greensburg,pa
    2018 RT-L , Blue
    Durham,Maine
    The first owner of my bike put a seat belt in for his wife, because she would get on and fall asleep on him!! It was the first thing to be taken off when I rolled it home!!
    2012 RTL , Pearl
    May 2020
    Walker, LA
    I will be installing a pair soon!
    May 2021
    Nevada
    That's an idea (seat belt), but we haven't had a chance for a long ride yet weather being what is is here in Nevada, but I will keep that in mind if the time comes. She should be good with just the arm rest and I am considering the driver back rest so she would be boxed in.
    Active Member C. Lee's Avatar
    Feb 2016
    Silver Lake, OH
    I just put them on my 21 RTL. The installation was fine but the finish left something to be desired. There was a significant gap between the rear of the bracket and the plastic. I had to trim some of the old plastic that is supposed to be replaced to fill in the gap. Wife likes them a lot. Chris
    2021 Spyder RT Liminted , Marsala Red in Black
    Durham,Maine
    Oh ya, if you do the back rest and arm rest, she would have to have a nightmare to jump out of that box!!
    2012 RTL , Pearl
    Dec 2020
    Hartwell, Ga
    Not knowing your wife but if she is on the larger side the back rest might not work.
    My wife can barely squeeze in with my Utopia but it is easy to remove should I need to.
    Sep 2021
    Florida
    I installed them on my 2021 RT, took 45 minutes. You can get the instructions on BRP installation site. Now If I could only get a passenger cup holder!!!!!!
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    Quote Originally Posted by Okeefjr View Post
    Diamond R makes a good set.
    Jan 2021
    Long Island, NY
    one thing to keep in mind, the showchrome mounts to the top case, so if you remove it, the arm rests come off with the top case (great feature) the look of no top case and arm rests installed is silly IMO.....
    2021 Sea to Sky
    2020 600 , gloss black
    Mar 2020
    West Bend, Wisconsin
    I had the arm rest installed when I bought my 2021RTL. But when I got home they did not reach my wife's arms, she only stands 5'4". So I cut an extension out of metal to raise them about an inch up. Now she is happy.
    May 2019
    Springdale Arkansas
    Thanks for the info. About the ram mount plate, I have the plate and know where you’re talking about but I don’t know what size bolts to use. Are they metric or SAE? I saw a guy at our last rally yesterday in Nixa Mo but didn’t get the chance to talk to him much..
    2013 Spyder RT Limited , Metallic Brown
    Oct 2021
    Wichita, KS
    Quote Originally Posted by C. Lee View Post
    Exactly what I did. That gap is ridiculous! Especially for the price.
    Quote Originally Posted by Speedy88 View Post
    Great idea!
    Peter Pan has struck again!
