If you have an RT the wiring runs down the right side. OEM setup is 1. Through the center of the handle bars 2. than to the right and 3. along the right side it will plug in to the speaker input 3.5 mm and than a two pin power plug the rest you just tie up. You will use cable ties to keep everything neat and in place.
Non OEM setup: I have seen where the wire was not run down the middle but down the side handle bars before also so that maybe an option.
My Spyder
