Page 30 of 78 FirstFirst ... 2026272829303132333440 ... LastLast
Results 726 to 750 of 1932
  1. #726
    Feb 2019
    Portland, Oregon
    Thanks to my HF angle grinder for the foot rests.
  2. #727
    Aug 2020
    NM
    I put a new Spyder Blue Ridge Windshield on my 2016 F3s. I know many don't like the Blue Ridge Windshield, but I love it. I documented my installation by creating this video and provided instructions for others who wish to install the same windshield.
    https://youtu.be/4Xlovp_R-_E
    I also installed an Adjustable Sport Windshield on my 2021 Ryker Rally Edition. I documented my installation by creating this video and provided instructions for others who wish to install the same windshield.
    https://youtu.be/uBZrQefpy0c
  3. #728
    Mar 2015
    forrest above Reno, Nv
    Added a tstrip of tape to the top of the TricLED " Fenders" leds as they are silly bright and distracting at night. Next to test the added tape on a night ryde.
    Lew L
    2014 RTS , Circuit Yellow
  4. #729
    Jan 2021
    northeast pa.
    installed a set of Grip puppies, love them... also hooked up a pigtail to the battery for a battery mantainer...........
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
  5. #730
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    Installed a Lamonster handlebar riser on my 2021 RTL. Very well made I must say !
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
  6. #731
    Nov 2020
    Lincoln, Nebraska
    Check the front sprocket for the red mist. I’m one of the lucky ones!
  7. #732
    Oct 2015
    Lynden, WA
    2017 F3T. Took my OEM gas cap apart and filed down and polished the locking tang.
    Lubed and reassemble the bits. It now works GREAT.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  8. #733
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Haze View Post
    I did that a couple years ago and it has worked fine ever since.
  9. #734
    Mar 2021
    Arizona high country
    I installed some short reach bars that I got from a fellow SL. Tried them at the highest position as I thought I would like that, but I didn't. Now they are at their lowest and closest position and I think this will be where they end up. Only had time for a short ride, but seemed better than the stock bar/position. Only took about 25 minutes to install. Nice that BRP leaves enough cable to allow changes like this.
  10. #735
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    Installed wide view convex mirrors to assist me in changing lanes more safely.
  11. #736
    May 2021
    Nevada
    Drove her to work, as it is now my daily driver. She's only two weeks old still getting use to going from 2 - 3 wheels, but so far loving it.
    2021 Sea to Sky , cyclops light, front fender light/turn signal, rear run/brake/ turn signal LED strip, BRP floor board light Green
  12. #737
    Vermont
    Nothing. It is my garage life got in the way!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  13. #738
    Mar 2021
    Didn't actually do anything to it today other than add some miles. Momma and I did a 90 minute ride through some of the backroads here in North Central AZ. Saw lots of pronghorns, a couple of deer, and since this is mostly ranch land a ton horses and cows.
    When we got home I discovered my Baja Ron sway bar had been delivered, so I know what I will be doing to it tomorrow.
  14. #739
    Sep 2015
    Chilliwack, BC. Canada
    Went for a ride with a friend of mine...did the circle tour out to Agassiz, down to Mission, crossed over to Abbotsford and then back home. Stopped for lunch at the Historic Dewdney Pub, half way through the ride. Great ride, great food, great riding buddy.
    Once home, I discovered that the Fobo 2 that I had previously ordered had arrived, so I installed it on my RTS.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  15. #740
    Mar 2021
    Just doing a little planning today. Friday I started the install of the Baja Ron sway bar I ordered through Lamonster. After the bar was in I went to install the links and discovered I was missing the spacers. A call to BR and they are on the way so I can get it finished. If you are prepared with all the tools and the means to get it high enough the install should not take over 90 minutes.
    I have my oil and filter in hand, and am waiting on my Garmin XT to arrive. I will install the GPS and do the oil change at the same time since they both need to have the right side panel removed. I will also install the sway bar links at that time. Friday we are planning a 'ride to lunch' with friends up to Jerome, AZ. This will be a good test for the sway bar. I will keep you posted.
  16. #741
    Member PharaohRider's Avatar
    Apr 2021
    VA
    Yesterday I installed my first mods to my 21' F3S Special. Wait, I take that back. About a week ago I installed the removable drivers backrest. Yesterday, I installed the ARC LED Daytime Running Light/Fog Light kit from Sling Mods. I also installed my USB port for phone charger. Instead of mounting at the front of the bike, I installed the 12V USB under the rear seat in the stock port and then ran a 6ft lightning cord to the front. My phone holder is handlebar mounted so I didn't want to go with the kit to mount the accessory and 12V port. I ordered a magnetic cord holder on Amazon to hold the cord in place and a dust/weather protector when not in use. The cord holder has an adhesive base so i just stuck it in place. We'll see how it holds up in the heat and direct sunlight. Only other concern is how long the cord will last but if I have to replace it it won't be too hard to do. Having the dual USB in the rear works well for when I have a rider I can easily plug them in so they can charge while riding.
    Cord Holder
    https://www.amazon.com/Sinjimoru-Mag...NrPXRydWU&th=1
    Dust Cap
    https://www.amazon.com/Cozy-Lightnin...NsaWNrPXRydWU=
    2021 F3-S Special , Gravity Grey
  17. #742
    Linden, CA
    Default Here is whatmy adult son did with mine
  18. #743
    Sep 2015
    Geez Dave, that doesn’t look good....is he ok, or will he be once you’ve had a “talk” with him?
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
  19. #744
    SoFlo
    Ours is pretty much dialed in, so not much happening with it.
    A friend bought a 2021 RT Limited Dark last week.
    Helping him, last night I did a quick check and front wheel alignment. This morning I accomplished adjusting the belt tracking.
    Gave his a short test ride, handling is much improved. Will let him put a hundred more miles on it. Verify the belt tracking is legit, then do I will do a full laser alignment and recalibrate the sensors.
    Last night was old school. Factory delivered the wheels were toed out. He remarked the Spyder was twitchy. Used my automotive alignment setup and dialed some toe in at each side equally. Required 1/2 turn total, which is a lot.
  20. #745
    Mar 2015
    Modified ( seriously opened up ) the front intake of the 2014 RTS. Intake air must make a 180* turn to enter the convoluted intake track.
    Lew L
  21. #746
    Jan 2015
    southern WI
    Loaded on the trailer and ready for a trip west to cruise around the Black Hills for a week with 4 friends. Cannot Wait!!!
    2016 RTS , Pearl White
  22. #747
    SoFlo
    Quote Originally Posted by Lew L View Post
    Lew L
    I modified our 2014 RTS intake duct many years ago. Before making changes, I did some quick measuring and calculating. The Can Am engineers did pretty good matching the air intake duct to the expected and maximum throttle opening AND designed the system as a cold air intake with a large still airbox.
    I modified only the forward facing inlet.
  23. #748
    Mar 2015
    That's what I did. Some cutting to remove the blockage and some heating to open up the black plastic.
    Lew L
  24. #749
    SoFlo
    Lew L
    I skipped altering the ducts shape. I found, if I recall correctly, behind the forward facing inlet, the duct has an opening that is fairly large. Truth told, I should have tested a different setup I came up with. Sorted out details to mount a large filter, unprotected, onto the still airbox. My greatest concern was not having 100% cold air intake when moving.
  25. #750
    Mar 2018
    mississippi
    We added new sheep skin seat covers from Black Sheep Trading Company. My wife has now named the Spyder Shaun!!
    2015 Can Am Spyder RT Limited
    Magic Mirrors
    Short Antenna
    LaMonster Dual Power Plate
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
