Results 1 to 18 of 18
    May 2013
    Indiana
    Default My 2021 Rides Like A Buckboard
    I picked up my 2021 RT Limited last week. I'm worried that I have a problem with the automatic suspension feature. The ride is very "harsh" . Almost like there no suspension, or it's "wound very tight". When I come to a stop, it feels like it "settles". I've been riding solo to get accustomed to all the new features.
    This is not my first RT Limited. I traded my '15 in on this '21. I'm really missing the adjustable suspension feature right now. Is there a way that my dealer could make some adjustment to the auto suspension setting through the BUDS under warranty??? If I explained my issue in this manner,would my dealer understand my issue???
    Thanks in advance for any help that will come my way.
    Mike T
    2021 Marsala Red Metallic RT Limited
    Oct 2020
    Arizona
    I wondered if my RT-L auto level was working. So I manually release the air in the suspension at the schrader valve and watched watched the rear go down. Started it up, and put it in gear(I think), and it came back up. My pump is very quiet and/or my hearing range misses hearing the pump run.
    Sounds like yours has an issue.
    Hamburg pa
    take it back to the dealer. my sea to sky did the same thing. it was a senser programed wrong from the factory.
    Feb 2020
    N. Wilkesboro, NC
    Check the air pressure in your tires first. Most dealers pump them up to the max pressure.
    May 2013
    Indiana
    One of the first items on my checklist was to check the tire pressures. The 2021 Owner's Manual has only one tire pressure listed for the fronts and rear. 20 PSI-front, 28 PSI-rear. My fronts were high, my rear was low. My 15 RT Limited gave a range: Front 20 PSI +/- 2 PSI, Rear 26 PSI +/- 2 PSI.
    Dec 2020
    Hartwell, Ga
    Also look to see if the arm going to the air valve is attached. There have been some to report that it was not hooked up from the factory.
    May 2013
    Indiana
    I want to say thanks for all the input. Rode my RT Limited To my dealer late this morning. Got me right in for a Buds diagnostic. Nothing out of range. However, the service tech reset the zero on the R1 sensor to his weight of 260lbs. He told me the "relaxing/setting" after coming to a stop is normal. Something about how the auto system senses the motion of the rear tire. Hope I haven't been fed a line of bull*****.
    Sep 2018
    greensburg,pa
    Yes when you come to a stop the rear end maybe a little higher so it lets out some air to correct the height.
    2018 RT-L , Blue
    Jan 2021
    Oklahoma City
    Shawn Smoaks mentions the issue in the you tube post found in the link below. He never said exactly what the issue was but he seemed familiar with the issue. Seems it was a mechanical type issue vs firmware as he mentioned a bolt.
    https://m.youtube.com/watch?v=MQEeh8J3W1o&t=615s
    Active Member Papa103's Avatar
    Aug 2019
    Maine
    I went from a 2019 to a 2021. I didn't notice any difference in ride. My front tires are 20 psi and the rear is 28 psi. I can confirm that both of the Spyders will, at times drop a little air in the rear suspension when at a stop. I notice it more when riding solo. You can check the air, I'm not sure how much they are suppose to have. If someone doesn't chime in with the normal psi, pm me and I will put a pressure gauge on mine and let you know what mine is at.
    2021 RTL Chrome Deep Marsala
    HELI Bars
    Garmin Zumo XT
    USB power port
    Front fender lights & Sequential turn signals
    Front LED Auxiliary light
    Flashing brake module TricLED
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    2021 RT Limited , Marsala Red
    Harrington, Australia
    Quote Originally Posted by Adventurer View Post
    Yeah, that was where some dealers “forget” to bolt the bag sensor to the frame, Adventurer.......tends to limit the auto operation of the airbag
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2012
    Stetson, Maine
    To me it sounds like the ACS rod is not connected or incorrectly installed.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Aug 2020
    Creal Springs, Illinois
    Arm that activates the compressor is bolted to an attachment point. If tech never put the bolt in, simply doesn't work.
    Jul 2020
    Decatur, IL
    Quote Originally Posted by Papa103 View Post
    How do u check the air pressure (rear suspension) on a 2021 RTL.
    May 2013
    Indiana
    Quote Originally Posted by Jcummins View Post
    How do you check if "the bolt" is there, not there, or improperly installed. Can it be seen with the '21 Spyder on the ground, or do you need a lift???
    Aug 2020
    Left side behind passenger footpegs area.
    May 2013
    Indiana
    Checked. Yep, it's connected.
    Sep 2009
    La Valle, WI
    My 18 F3L settles when I come to a stop. It's normal. Mine rides very nice. Not harsh at all and I'm 230 lbs
    2018 F3 Limited , Oxford Blue
