Results 1 to 10 of 10
    Jul 2018
    Saskatchewan
    Question Sea Doo parts - are the oil filters the same?
    The nearest Spyder dealer is 2-1/2 hrs from me but there is a SeaDoo dealer 45 minutes away. Are the oil filters/O rings the same on both land and sea 1300 engines?
    Last edited by Peter Aawen; 04-27-2021 at 07:42 PM. Reason: 'Sounder' = Spyder. ;-)
    Sep 2012
    Stetson, Maine
    Check the parts fische for both the Spyder and the Seadoo. Good luck.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jun 2011
    Near Lexington, NC
    Sorry, I don't know the answer but am doubtful unless the Sea Doo uses the 1330 motor. Can't you order what you need online?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Bossier LoUiSiAna
    Don’t forget sponsor Baja Ron. Alternatively https://www.cheapcycleparts.com/ & would try asking a dealer tech if there are any special “tricks” for using alternative parts.
    Mar 2017
    Salisbury,NC
    Hi Flow 551 is alternate in auto stores, i use these once i found out what filter was the same
    Dec 2012
    Murphy, NC
    You can always order your filter and O rings from BajaRon a site sponsor.
    2020 F3 Ltd
    Spyderpops Bumpskid
    May 2009
    Connecticut
    Sea-doo has No 1330 But you can use the Sea-doo 90 hp spark filter in the Ryker because its the same engine. Both are priced different?
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member crossbowme's Avatar
    Jun 2012
    South China, Maine
    The 1330 is a snowmobile engine. If the stock number is the same it will fit. Should be some snowmobile dealers around you.
    2021 Can Am Spyder Sea-to-Sky
    One of the Sea-Doos uses the same filter but the can configuration is different and the O-rings look to be a quite a different group. Go mail order from Baja Ron!
    May 2014
    Benson, NY
    I have 2 non spyder CanAm dealers close by, when I mention that I'm trying to cross reference a part to fit my spyder they suddenly forget how to operate a computer and reassure me that there is nothing they can do.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
