Results 1 to 9 of 9
    Feb 2021
    LA
    Default Phone mount for center of bars - what size allen key to undo h/bar bolts?
    Purchased a tracform phone mount that will be mounted to center of bars. Does anyone know what size allen bit is used to remove one of these screws.
    You don't say what year and model Spyder you're talking about but a quality 7mm Allen should fit both F3 and RT. Those bolts are heavily dosed with a 3M thread locker.
    Mar 2021
    Haven, Ks
    Good luck! I had to use an impact wrench to loosen mine and a heavy duty one at that.
    Feb 2021
    LA
    Quote Originally Posted by CHUCK1 View Post
    2020 RTLimited
    I've never had to remove one but I've read hereon about some folks recommending heating the bolt(s) with a soldering iron to soften the thread locker and do have a long breaker bar handy.
    Mar 2021
    Arizona high country
    I have changed mine out, but make sure you use a good tight fitting Allen wrench. I prefer to use Allen head sockets to standard wrenches.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    I have replaced one of mine with a stud and coupler to mount a RAM ball to. The bolt didn't come out that hard - I used a long Allen socket and ratchet.
    1976 RD400c
    Dec 2020
    Hartwell, Ga
    2020 RTLimited
    Your tool kit will have what you need in it.
    Aug 2019
    Minnesota
    Quote Originally Posted by rjinaz86323 View Post
    Yes
    I also used a socket type Allen wrench (craftsman). I have see some with a lot of chamfer on the end which seems to reduce the amount of contact buy lifting it slightly up from the bottom of the hole. Mine are pretty much flat on the end.
    I used a long breaker bar and proceeded slowly. Keep the tool firmly seated and aligned. Easier than I thought it would be.
    ba
    2019 F3-T Liquid Titanium
    “we are all products of those to whom we have chosen to listen”
    2019 F3T , titanium
