Results 1 to 14 of 14
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Default Check the Oil cold before riding; or hot after?
    Cold before first ride or when hot?
    Oct 2020
    Arizona
    Quote Originally Posted by ricford View Post
    Engine Oil Level Verification
    In order to perform the engine oil level
    verification, the engine must be at normal
    operating temperature.
    1. Take a ride of at least 15 km (9 mi).
    2. Park the vehicle on a level surface.
    3. Let the engine idle for 10 minutes.
    4. Stop engine.
    NOTE: Engine oil level verification
    must be performed within 2 minutes
    after engine stop.
    5. Open the seat. Refer to OPENING
    THE SEAT inEQUIPMENT.
    6. Unscrew and remove the oil dipstick.
    7. Wipe off the dipstick.
    8. Reinsert and completely screw in
    the dipstick.
    9. Unscrew and remove the dipstick
    again.
    10. Check the oil level on the dipstick.
    It's in your operator's guide.
    Oct 2019
    Roswell, GA
    Exactly- I have never had a vehicle that varied so much if you don’t follow the procedure in your ops manual. Brought mine to the dealer for oil change as part of a 14k inspection and told them to put an extra quart in the frunk for road trip use. I was surprised when my spare quart only had a 1/4 of the bottle left so I checked my oil by the ops manual and you guessed it- overfilled by 3/4 quart.
    I only check the oil .. After a normal length ride ... if there isn't an oil puddle under the Spyder, then except for normal amount of oil use ( for V-twin, 1330 don't use oil ) otherwise you are just wasting gas and time ..... good luck .... Mike
    Bottom line: recommended to check the oil while hot. As in after a ride. Particulars can be found in the manual. Manual, I don't need no steenkin manual!
    Feb 2012
    Spring City,Utah
    The oil tank on my 998 (2012 RTL) has a little sticker that outlines the oil check procedure. Do the rest of you not have such a sticker on your tanks?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2020
    Hartwell, Ga
    On my 2020 RT-L, No Sticker but it is in the manual.
    No sticker here. You may be the only 'Stickered' Spyder on the road!
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    If you have the 1330 engine here is an older thread from BRP, https://www.spyderlovers.com/forums/...ngined-Spyders
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Here is a tip to aid seeing the oil on the dipstick: use a UV LED flashlight and check it in a dark or dimly lit area. Most oils show up very well under UV.
    1976 RD400c
    Feb 2012
    Spring City,Utah
    I doubt that, although there are not a lot of Lava Bronze, Brown seat 2012 RTL around.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    INDIANA, USA
    Default Oil Check
    Check the oil after riding your Spyder for 10-15 minutes.
    I use a white paper towel for Check. ....
    ENJOY YOUR LIFE WITH A SPYDER
    My Pearl White 2013 RT Ltd also has the sticker on the oil reservoir, and I've seen quite a few more V-Twin motored Spyders similarly stickered - none of them Lava Bronze tho?!
    That said, my RT-L DID leave the factory with a Brown Seat - maybe that's the common factor?!? But I don't think too many of the other's I've seen were Ltd's, and none of them had a Brown seat, so there goes that theory.....
    Just as a quick aside, if anyone wants an almost un-ridden Brown Seat & Pass Backrest off a 2013 RT Ltd, please drop me a PM - cos no further discussion of my 'Brown Seat' will be entered into in this thread!
