Results 1 to 8 of 8
    May 2017
    Central Texas
    Default Will a 315 CCA Replacement Battery work? Recommend alternatives?
    This morning I had to push our '16 F-3 LTD out of the garage & onto the street. 2 hours later when I started the tryke, it was slow to turn over. I'm anticipating it will fail its load test on Saturday. I have a $100 credit at the local H-D dealer. I noticed the Harley battery for Softails is rated at 315 CCA vs the Spyder's Yuasa at 350.
    My question is, has anybody ever had problems with a replacement battery at 85 to 90% of the original equipment specification?
    Any recommendations for an AGM replacement, I'm wanting to stay away from the Old Skool Acid type.
    Last edited by Peter Aawen; 04-16-2021 at 06:41 PM. Reason: Removed Prefix - this is a 'What should I use?' question not a 'How To: DIY' guide. ;-)
    Apr 2020
    Edgerton,WI
    Yuasa battery is rated at 350CCA and is the OEM Model.
    2019 F3L , Covid Blue
    Stick with the Yuasa or, if you choose another brand with the same CCA as the Yuasa. Would you buy a tire with less tread than spec because you had a credit for a thinner sneaker?
    Quote Originally Posted by Matahead View Post
    Spyders have a High power draw ( at start-up ) I'd be concerned with less than 350CCA ..... I have a 14 RT and it has always been slow to start , even after I put in a brand new one ..... MY advice is get it load tested. I bought a small Lithium battery JUMPER and keep it in the Spyder .....good luck ..... Mike
    May 2017
    Central Texas
    Quote Originally Posted by bikerchris1270 View Post
    I know.
    Oct 2011
    Kalamazoo, Mi
    Here is a link to Motobatt specific to your model
    https://www.motobatt.us/parts-finder...20F3%20LIMITED
    I have used these previously in a 2000 Gold Wing SE and they really do the job well. The gold wings won't start if the battery doesn't have the power needed; they will crank, but without the juice needed they won't fire off the sparkplugs at the same time.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    May 2017
    Central Texas
    Quote Originally Posted by IGETAROUND View Post
    Al in Kazoo
    Thats the battery we have, its only 300CCA and causing problems. Took it out over the weekend, checked the battery, it checked okay. On a ride tonight, I got all sorts of codes. The parking break doesn't think its on. Very slow to start. I want to shoot the piece o scat. But gonna put a new 350CCA battery and go from there.
    Oct 2011
    Kalamazoo, Mi
    Sorry, that's Motobatt site specific recommendation for the bike.
    Al in Kazoo
    2018 F3-T
