Aftermarket sounds... How do I make something work?!
I just downloaded some music to a flash drive , went out and plugged it into my 2019 F3 Limited made what I thought was the correct adjustments for the 'sound system' and nothing came out !! After a small investigation I read that flash drives are not compatible with the 2018 2019 models. Are you kidding me .. its bad enough some genius thought preset radio was a good idea (they must not travel very far from home) but then they design a system that doesn't work with this alternative !! anyway , would appreciate suggestions on how to make something work because every time I ride I go beyond the local stations and not always in the same direction and I sure as hell am not gonna stop and try find new stations.
Ozzie Ozzie Ozzie
I cured that problem with a subscription to XM radio .... Lately I've seen their ads that offer a FREE receiver with a subscription .... I pay only $ 5.00 per for 6 mos. ( that's my riding season .... Mike
Me too! Love it.
Link a smartphone via bluetooth to your BRP Connect system and it will play the tunes stored on the phone. Its one of the few things BRP Connect system actually does ok.
you can get xm on your phone plug in and play many channels
Those with Satellite radio--I would like to add to my 2020 F3-T. I know I will need a receiver, antenna, power. (and a mount but would like to keep in glove box on top of dash for easy removal). can I get power without hard-wiring? Like, USB or 'pin' connection in glove box? hoe/where do you put antenna and run necessary wiring? ...please add any comments you care to share.
I am reasonably handy and would like a plug and play if possible and not have to visit Dealer! Thanks guys
Using the phone works great. I can get iHeartRadio or Sirius satellite radio along with my own tunes. Zero frustration.
I installed an XM radio on my 20 RT. I mounted the antenna on the back opposite the RT antenna. I mounted the XM head unit on the left side of my dash using the mount it came with and 3M red tape. I doctored a USB cable to pull the 5v from the USB socket in glovebox and plugged the audio out into the AUX IN plug in the glovebox. all cables are routed thru steering head. You either route the 5v and audio under and back into the glovebox in case you want to re-use the RT connectors for something else or push the RT cables back thru the bottom to free up the box space.
I installed an XM receiver in the glove box of my 2018 RTL. I pulled 12V from the unused accessory fuse and connected the audio output to the AUX plug with a 3.5 mm male to male barrel connecter. I had to select the "high" audio out setting on the receiver to get sufficient volume. I initially mounted the stock antenna on the top of the trunk, but experienced intermittent loss of signal. I purchased the "high gain motorcycle antenna" from Satellite Superstore, and mounted it on the right handlebar, which completely eliminated the problem. I brought all of the cables into the glove box through a 3/8" hole drilled in the side of the glove box pan.
The whole installation is completely weather proof, but requires opening the glove box at a stop to change channels.
Like others in this thread suggested, I am now streaming XM satellite radio via blue tooth. Service is free if you are already a XM subscriber. Question: can you change radio channels from Spyder control panel/switches? ie. switch among channel favorites set on phone or even scroll thru all channels?
flash drive works on a 2017 f3,after that year its seems to be all Bluetooth
