Results 1 to 9 of 9
    Jul 2015
    Wisconsin
    Default OEM backrest adjustment?
    Just got a used 2014 STL with the Can-am backrest (not pictured). Is there any way to adjust it back a bit? I feel like it pushes me forward.
    Jun 2013
    Fleetwood, PA
    Passenger backrest? I do not believe BRP makes a driver backrest for the ST. If you have a driver backrest it may be aftermarket seeing that you bought it used
    Mar 2013
    Oz
    Default backrest adjustment
    If it's the passenger backrest, yes it does adjust but I can't quite recall how... tip it forward and it slides on two metal prongs back and forward (I think)
    If it's the driver backrest it is aftermarket (lucky you) and it likely has a little screw which you can wind by hand to change the angle of the padding, it would be at the base of the prong which has the padding on it, before the bit that goes in the seat.
    All sounds a bit irish, but hard to describe.
    Jul 2015
    Wisconsin
    Default Passenger backrest
    I'm asking about this ST backrest as seen on the Can-am site.
    http://store.spyder.brp.com/product/...enger_Backrest
    May 2011
    Karaka NZ
    Quote Originally Posted by Cognac View Post
    Unfortunately that backrest is the non adjustable type
    2015 F3 , Black with Blue Graphics
    Jul 2015
    Wisconsin
    Don't know why, but after we added the armrests the back support felt ok. Really enjoying being a passenger now - not as much as being the rider, but must be willing to share the fun.
    Jun 2015
    Tucson
    I have a 2014 ST S with the same backrest and it is not adjustable.
    Active Member JCGammack's Avatar
    USA, Iowa, Hayesville
    Default Glad you are enjoying.
    Good to hear that the arm rest are working well for you. When my wife and I travel we switch off piloting and riding about every tank of gas. We have started a rule that the passenger is responsible for taking pictures as we go. Works out pretty well.
    Chris Gammack
    You don't know what I don't know. I don't know what you don't know. All I can say is at my age what I don't know is huge.
    I call the Avatar "The first fifteen feet."
    Active Member Spyder Hawk's Avatar
    Feb 2015
    California
    Cognac, where did you get the armrest for the ST? I can't find any.
