Results 1 to 24 of 24
    Apr 2015
    Lodi WI
    Default Red Dust front sprocket
    Can someone help me find the thread or tell me what the red dust on the front sprocket issue is?
    Also, which Tupperware comes off to get to the oil filter? Don't have my manual.
    Thanks Dennis
    Feb 2019
    Portland, Oregon
    What model and year? Red dust indicates worn pulley splines. Park brake on, loosen bolt. Get the rear tire off the floor enough to rotate it, park brake off, in neutral and walk the belt off the rear pulley. Before removing the front pulley, check it for play, the should be none. If there's none, clean both splines perfectly and apply a veneer of Moly Paste - not Moly Lube.
    If there's play/slop, you'll need a new pulley and bolt.
    Apr 2015
    Lodi WI
    2016 F3L. I'm still under warranty. This should be covered if there is play in the sprocket. I'll get right to the inspection.
    Which side comes off for access to the oil filter?
    Sep 2020
    Platte City, MO
    I believe it's recommended to replace the pulley bolt any time it is removed/loosened.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Dennis in Lodi View Post
    The right side. Have you removed that panel before? If not, remove the the access door. You'll see 3 push pins, but remove the 4 screws first, then the pins. It's a tight squeeze, but you can get the filter out if you move the brake reservoir out of the way a bit.
    Are you doing an oil change? Note that there are 2 drain plugs; one is a torx recess and the other an allen recess. Use a ratchet handle and TEST THE ROTATION (lefty loosey) before appying it. Be sure to have the dipstick loose or out.
    Feb 2019
    Portland, Oregon
    Hey Dennis,
    I just noticed what town you live in. I was there many years ago and could not find my way around, or how to get out of town, so I wrote a song about it. Here it is....
    https://www.youtube.com/watch?v=yA7iGxV6rt4
    Apr 2015
    Lodi WI
    Thanks, The pulley seems tight. I applied a little blue lock tight to the bolt for now. I'm going to call the dealer tomorrow and have them inspect it. It's a lot of red dust that was not there last spring or 10,000 miles ago.
    Once I found the oil filter I remembered how to access it. Every vehicle I own I write service notes, and I have the torx and allen size noted. Also my notes reminded me to only put in 5.6 quarts as any more pumps out the dip stick under high rpm.
    I really enjoy the long oil life and trouble free riding I have gotten.
    Thanks for the help
    Dennis
    Apr 2015
    Lodi WI
    Update: dealer says sprockets are a wear and tear item like the belt. So my BRP extended warranty isn't going to cover this item. Seems the sprockets could be in short supply or delayed delivery from Canada.
    Dennis
    Sep 2020
    Platte City, MO
    JMO, but I think your dealer is blowing smoke. Belt sprockets/pulleys should not wear out for many thousands and thousands of miles. The belt
    may wear out, but the sprockets/pulleys should still be going strong. It isn't like chain and sprockets. And the sprockets/pulleys aren't failing from
    use, but from movement on the shaft splines, which should not happen.
    Feb 2019
    Portland, Oregon
    Fortunately, there is an improved version - it is white. Also fortunately, they don't cost a lot - somewhere near $100 plus the $10 bolt.
    Apr 2015
    Lodi WI
    Yah, I'm cutting my losses based on 2 things. It would cost me my time to trailer my Spyder 2 ways even if it was under warranty. And the cost of $130 with tax is off set by my truck fuel savings and time.
    I have Anti seize which I use on similar applications.
    What is Moly Paste?
    Feb 2019
    Portland, Oregon
    Cheapmotorcycleparts.com discounts, but make certain you are getting the newer one.
    Here's a link to Moly Paste - it has mostly moly and a bit of lubricant.
    https://www.ebay.com/itm/Genuine-OEM...sAAOSwNSxU7OgC
    Apr 2020
    Edgerton,WI
    What is Moly Paste?
    Shop manual calls for KLUEBER Paste......research for answer.......$$
    I use the Honda stuff....
    L
    2019 F3L , Covid Blue
    Active Member ris's Avatar
    N.H.
    I have a 2015 RTSE6. I have the red dust . About 8,000 miles.
    Could someone please post the part numbers for both the new white front sprocket and bolt. Also the torque spec on the bolt. Thank You in advance.
    Apr 2015
    Lodi WI
    Update,2: I loosened the belt but could not get the front sprocket to loosen. I had to use a large gear puller and it was tight until the very end of the travel. Upon inspection, I felt most of the red dust was from the inside of the pulley as the inside black paint had failed to protect the metal like the outside black paint. The old pully splines were fouled with red dust and the shaft had to be cleaned of red dust.
    The new pulley's white paint seems to be powdered coated and much more durable. I used Permatex anti seize as it has the heat resistance and release properties needed for this kind of use. The new bolt comes with thread lock applied. I used a single jack on the left side of the swing arm. I don't believe I could have gotten the pulley off without the gear puller. The drive splines cleaned up like new. About an hour from start to finish.
    Just wanted to share.
    Dennis
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    Good to have an update. GOOD job!
    Aug 2015
    Northern KY, Butler
    Does any one have the torque spec for the bolt that holds the sprocket on?
    Apr 2020
    Edgerton,WI
    9096AC83-06F2-408E-B61B-0BB386AD4941.jpg110 ft lbs..NEW BOLT.....I believe this is the updated spec......it what I torqued mine to.
    Some of the early shop manuals stated 95 ft lbs.
    Dennis
    Just a heads up ....... I'm pretty sure " Anti-Seize " paste is NOT what you should use .... there are special " moly " pastes made for type if application. ..... I would check some of the other posts or PM ... PMK ...... jmho .... Mike
    Aug 2019
    Stoughton, WI
    Your Honda dealer should have this...
    2022 RT Sea To Sky
    Jul 2016
    Huntsville Ontario
    We have a 2016 RT-L with 23,700km (14,700miles). During my spring pre-season check, I noticed red dust starting to appear of the front sprocket.
    A few questions...
    - Is the RT and F3 front sprocket the same part #. In reading the forums I believe the new part is #705503244
    - Is there a TSB or something from BRP which I can ask the dealer to reference in case they are not aware of this issue?
    - Does BRP cover the cost? My warrantee is expired, but BEST is still active
    - In following the new install procedure using Moly Paste, can the bike be ridden immediately after installation or does it need to cure? (My dealer does all service while I wait since I have no way to get back home)
    Thank you for your advise! (I am unable to do the repair myself).....Brian
    2016 RT Limited SE6
    Feb 2019
    Portland, Oregon
    Yes, you can do it yourself if you know which end of the screwdriver is the handle.
    + With the parking brake on, loosen the pulley bolt.
    + Lift the rear wheel off the floor and release the parking brake.
    + Walk the belt off the rear pulley. Some loosen the axle and run the adjusters in, but I'm lazy.
    + Remove the pulley bolt and pulley. If pulley sticks, use a puller.
    Jul 2019
    UK
    If pully sticks squirt down the splines with a release oil or kerosine or anything thin and oily. I tried levers, hammer and all sorts, finally gave it a skoosh of WD40 and went off for the puller, came back and off it slipped like magic - still amazed to this day how the rust dust wedges up solidly.
    Quote Originally Posted by Brian0
    1 = yes
    2 = Updated torque 111lb/ft (Personal opinion, at least that torque, I use higher! This is the key to it not happening again.)
    3 = Seems to depend on your dealer relationship with BRP.
    4 = You can drive it straight away, there is to setting or curing involved.
    Oct 2020
    Arizona
    Quote Originally Posted by PinkRosePetal View Post
    1 = yes
    Is the new bolt a 12.9 grade bolt? My 2018 has a 10.9 grade bolt and specs for a 10.9 grade 12mm bolt is 77 lb ft. My pulley slide right off and appeared it was installed with while lithium grease. I cleaned it all up and coated with moly paste. Will have to torque that bolt once the wheel in reinstalled with the new tire.
