Results 1 to 22 of 22
    Active Member telespec's Avatar
    Nov 2012
    Houston, TX
    Default Rear Tire Replacement
    I have a 2011 RTS SE5 with over 30,000 miles and the dealership want to charge me 250.00 to change my rear tire, are they trying to rip me off or is that a good deal?
    2012 RTS SE5
    SpyderPops BumpSkid Guard
    PowerSportsWraps Phoenix Bird
    GloRyder Lights for Front Wheels with Remote
    Lamonster IPS
    PowerSportsWraps RT Dash Kit Woodgrain
    Custom Dynamics Chrome License Plate Frame
    Shortee Antenna
    Knight Riderz Light Bar Blue
    Front and Back Spyder Decal
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    Lamonster LED Headlights and Fog Lights
    LED Tip Lights
    LED Light Strips for Front Fenders
    LED Light Strips for Left and Right Turn Signal
    Third Brake Light for Rear
    2012 RTS , Blue
    Durham,Maine
    Is that with the tire or just service charge?
    2012 RTL , Pearl
    Nov 2012
    Houston, TX
    Service charge.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
    Durham,Maine
    There shop rate must be up there!! I would say that's 2 hr job, maybe 3! But unless you can do it yourself, what you going to do?
    2012 RTL , Pearl
    Nov 2012
    Houston, TX
    Am stuck between a rock and a hard place.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
    Durham,Maine
    If your handy with tools, and have a place to do it, you can find all kinds of you tube video's that will take you step by step on removal of the rear tire, then you could have a new tire put on your rim and save yourself a little service charge money! But if your not comfortable with wrenching then your right, rock and a hard place!! How about a friend??
    2012 RTL , Pearl
    Nov 2012
    Houston, TX
    Thanks for the good advice and wish me luck and blessings.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
    Feb 2019
    Portland, Oregon
    If you R&R the wheel yourself, you can have a much superior car tire mounted at a regular auto/tire shop for less $$.
    Mar 2016
    Baytown, TX
    Was this at Mancuso? I recently priced a tire change at the gulf freeway one near the beltway on 45 and they wanted to charge me to 260 for tire change not including tire. At the LaMarque Mancuso they are charging me 160 to change the tire not including tire. My RT is there now. There is a member on here that was charging less but he couldn't get me into his shop until mid January. I'll use him next time and he sells/installs car tires on the Spyders. His info is below.
    Also my direct email is jcthorne@thornolis.com and our web site at thornolis.com
    2015 RT , Black
    INDIANA, USA
    Default Tires
    Good Luck on Your Mission. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2020
    Middletown, NJ
    IMHO, 2 hours is excessive to change the rear tire. I'm not a mechanic but I'm 'handy" and I R&Red plus balanced in ~1 hour for the 1st time last month when switching to Q5 tires. I would think a professional shop would be more skilled and do it in similar or faster time. The hardest part is getting the spyder high enough to drop the wheel.
    2020 RT base , Chalk White
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    OK, last year I had all 3 tires "made new" (labor only) for $120 in the Phoenix area. Look for a privateer who has worked on Spyders. They are out there at reasonable prices.
    Quote Originally Posted by RayBJ View Post
    .... I also had my rear tire swapped at SpyderFest in 2019 at a popular dealer there .... 35 min. - labor only .... they knew to remove the rear Shock bolt so my ( proper lower ) tension didn't need to be adjusted or even checked ...... Mike
    May 2009
    Connecticut
    Unless your going to be doing this a Lot of times its probably better to Pay $250 IF they allign the wheel properly because this can take a couple tries and each try is about 30 Minutes to adjust and test?
    Sea Doo GTI-SE 90 Jet Ski!!
    Nov 2012
    Houston, TX
    Thank you EDBLU for the information on Jcthorne, he took care of my Spyder did a good job and saved me lots of money. Had my tire replaced on 1-23-2021.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
    Mar 2017
    Salisbury,NC
    see what happens??????????? didn't like the cost, so asked for advice here, and BINGO, got the reduced price answer or other options. GREAT FORUM!!!!!!!!!!!
    Active Member jredman's Avatar
    May 2013
    Caddo Mills, TX
    Quote Originally Posted by telespec View Post
    I have the 2020 TR Ltd. I took off the wheel myself. Took it to my dealer. I had them order the new Kanine. Charged me $ 129 for tire and installed and balanced on the rim. Then I reinstalled the rim.
    Jun 2020
    St Augustine F
    I had my tire, drove to the mechanic in Daytona (I live in St. Augustine but this guy comes highly recommended) and got tire changed. He said my brakes needed replacement so I agreed to do it. Total price $180. It took him less than an hour after I checked in. BTW he did not do all the stuff the videos show. He jacked up bike from back and took wheel off. That is bound to save a heck of a lot of time aince he removed none of the tupper ware.
    Apr 2012
    Florida
    Quote Originally Posted by Brainsprain View Post
    Send me his name and number please? We need good people like this! Tom
    2020 Petrol Blue Metallic RTL
    Feb 2012
    Spring City,Utah
    There is no need to remove any plastic to remove a rear wheel. I have done 3 tires on my RT and never removed any plastic. Watch some you tube videos on how to do it and go for it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Houston
    On an F3 or F3S you have to remove the rear fender.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I know you done tons of these, maybe hundreds, but I never had to remove the rear fender on my F3 or F3-S(Daytona) to remove my rear wheel. I didn't take the rear shock bolt out either. Just jack it up high enough after pulling the axle and it rolls right out.
    2020 RT Limited , Petrol Blue
