Results 1 to 25 of 27
    Active Member Reacher68's Avatar
    Jul 2018
    Grand Prairie, TX
    Default Recommend or suggest any All-in-one portable air pumps?
    I have a 2016 F3-T and need to fill my rear shock from time to time. I'd also like to be able to refill my tires on the road. I bought a hand pump that works great for my shock, but it won't air up my tires. I have a 12v attachment on my handlebar and am looking for recommendations for a good portable pump that I can use for both my tires and shock.
    Thanks in advance for any help.
    2016 F3-T
    Places I've ridden.
    May 2017
    Mesa, Arid-Zone-A
    I have a Ryobi One+ portable inflator that I use for all my vehicles. It is easy to use, convenient, portable and no wires or plugs-ins to deal with. It will top off my car and truck tires. Battery powered by 5AH battery. The biggest drawback is that it is the size of an electric drill so may not travel well for you. I tried smaller portable inflators which were not up to the task and/or failed to last..... Jim
    Semper Fi
    Clinton, MS
    Try the Dynaplug Micro Inflator V2. Cycle Gear has it on sale right now. https://www.cyclegear.com/accessorie...rger%20list%29
    You should be certain the 12V attachment is fused to handle the current draw of the inflator you purchase or you're liable to toast some wiring.
    Oct 2019
    Roswell, GA
    I bought a Cycle Pump years ago and have been storing it in every new bike I get.
    https://shopbetamotorcycle.com/produ...iABEgKjOvD_BwE
    Oct 2020
    KS
    Antigravitybatteries.com has some choices to run off bike or power module.
    Bossier LoUiSiAna
    80295A64-0A9E-42C4-8C81-3A6D20B7B3B1.jpg as seen on TV: AIR HAWK PRO. 12VDC or rechargeable battery. Has been quite handy for many occasions, can be slow getting that last 1& 1/2PSI but better than alternative EB38940B-311A-4EB5-8884-2EEA358B936B.jpg
    *have not tried: https://www.amazon.com/Compressor-VE.../dp/B07ZFQJQRV
    Northern Kalifornia
    Exactly what I was thinking JayBros. Glad you brought that up. A toasted loom would be far and away more fatal than a low-pressure tire.
    Dec 2016
    Gold Coast, Australia
    Nov 2020
    Lincoln, Nebraska
    I carry five CO2 bottles that I picked up at a bicycle shop and I have a splitter that you hook the CO2 bottle up to and then you can hook it up to the stem of your tires or your shock. With the small knob on the splitter you can control the rate of flow and even turn it off and remove the whole system. The small CO2 bottle will contain it’s charged for about a week as long as you leave it attached to the splitter device. I carry it all in a small pouch with a tire plug kit. Works very well. I wish they made an air system that didn’t leak. An onboard pump would be nice.
    Oct 2011
    Kalamazoo, Mi
    Save your money on the others; this is the best portable compressor that you can buy:https://www.aerostich.com/a-to-b-uti...ompressor.html
    2018 F3-T
    2018 F3-T , Pearl White
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by IGETAROUND View Post
    +1 on the Aerostitch.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Oct 2011
    Kalamazoo, Mi
    And if you don't want to take my word, ask Joe or Ann Meyer
    2018 F3-T
    Feb 2018
    NorEastern, Washington
    Plarimer...
    If you have a leak in your system, fix it and the only issues you will have is temperature and altitude. As for the pumps, many here have reported them failing and they are expensive. I bought the 2017 F3T over the F3L for the added power. I figured I could add the pump if I wanted. I ride mostly one up and have found my perfect psi setting. My system doesn't leak.
    Regards,
    2017 F3T , Triple Black
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    harley-davidson.com/us/en/shop/compact-air-compressor-with-light/p/12700020 Very good size for our needs, plus extremely efficient. Ok price, and easy to find at your nearest HD shop.
    Active Member timd35's Avatar
    Aug 2019
    Texas
    Hello, I was looking for one as well. Question about the Aerostich. I noticed it is pretty open. Is that a concern at all?
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by timd35 View Post
    Timd35,
    No the openness isn't a problem, has nice hanging strap and will fill not only tires but is gentle enough to adjust the air bag on rear suspension. Ann and Joe Meyer use theirs at every laser alignment that they do!!
    Al in Kazoo
    2018 F3-T
    The biggest killer of these 'compact compressors' (well, after poor quality/construction, anyway! ) is over-heating during operation; so that 'openness' really isn't a concern at all!! In fact, it's a REAL ADVANTAGE!!
    Because the Aerostitch compressor is so open, it'll get rid of excess heat a helluva lot better'n most of the alternatives that you see around the place encased in placcy or metal boxes, and by doing that, it gets to minimise any over-heating issues & so run better for longer! And they DO generally work real good! Plus, the open-ness you're concerned about IGET helps them keep on doing that well past most of the opposition offerings!
    You could do a lot worse than get one of them!
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I have this one
    2018 F3 Ltd. , Black/Dark
    Nov 2020
    Lincoln, Nebraska
    You are correct, mine was the weather related as we are going through several temperature changes here in Nebraska. But for some reason after pumping it up to 28 pounds it is stayed there since.
    Jul 2010
    Las Vegas, NV
    We love this thing! Well over 1000 uses, we got our money’s worth in spades! Still going strong, no one has an excuse to not have properly inflated tires. The size of a tennis ball, takes up no room. Get one!!
    Joe Meyer
    Active Member rugercharger's Avatar
    ohio
    joe, were you referring to the aerostitch one/
    Dec 2008
    Syracuse, NY
    Since the Spyder has an auto tire in the rear and the aerostitch looks like a good pump with excellent reviews, can it be used with a Jeep Wrangler with stock tires? I ask b/c when I go to amazon.com there are many offerings and each one of them have a lot of 1 stars.
    Oct 2011
    Kalamazoo, Mi
    Yes he was, that's what they use
    2018 F3-T
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by wyliec View Post
    Wylec, don't know why they wouldn't work. Would need a 25 foot extension on the battery hook up to get to the rear tires.
    Al in Kazoo
    2018 F3-T
