Results 1 to 25 of 27
    Jul 2015
    Dorr, michigan
    Default Wiring heated gear 2020 RT
    Looking to run some wires for heated gear on my 2020 RT Limited from the battery back.
    Any idea or suggestions on an easy or good place to run the wires?
    On the 2015 RT Limited I removed all the panels, basically stripped it down to run the wires and hide them, I was wondering if there is a little easier way?
    2020 RT Limited , Petrol Blue
    Oct 2011
    Jacksonville,Ar
    I have mine mounted in the center console.6B415397-6616-4722-8CCF-8F778765956D.jpg
    The wires go straight to battery
    15 rt , yes Black
    Jul 2015
    Dorr, michigan
    Do you have one for the passenger?
    Sep 2018
    greensburg,pa
    I ran my + to the back of the alternator, very easy!
    2018 RT-L , Blue
    Mar 2013
    Quote Originally Posted by samewok View Post
    I did the same, but I placed the connector in the center of the blank switch.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Oct 2011
    Jacksonville,Ar
    That is where my garage door opener. also you can put a spliter from one to the other.
    15 rt , yes Black
    Jul 2020
    Decatur, IL
    I ran from the battery up into the glove box. I won't be riding dual in the cold weather and I just leave the glove box unsnapped while using the 12v cord. Seemed easy to do for me I might at some point change it but it seems fine for Doug just the way it is. Not fancy but gets it done and I didn't have to pull any panels off. Just used a long plastic wire tie up under the panel and pulled it into the glove box.
    Feb 2016
    I mounted mine lower on the left and the passenger one next to the heat switches. Both are run directly to the battery, which has the added benefit of being able to plug my battery maintainer into either one.
    2020 RT Limited , Marsala Red
    Jul 2015
    Dorr, michigan
    I like that location. I am going to see what it takes to get to that one.
    That's very well done. Are SAE receptacles easily sourced?
    Durham,Maine
    I think my wife could break that plug off in short time, getting on or off the bike!!
    2012 RTL , Pearl
    Feb 2016
    Yes. A quick search will find them. I can't remember exactly where I got these from. They have a standard SAE disconnect plug on the other end of the cable (about 6-8 inches long). This allows me to unplug the passenger one whenever I need to remove the side panel by the grip.
    Jul 2015
    Dorr, michigan
    Well it took me longer than it should have. Twin 3 year old grandsons were here for the weekend and needed my attention, and I was happy to give it.
    Here are the end results
    Thanks so much for all the input from everyone.
    A shout out to Bajaron for steering me in the right direction diffe new wiring leads!
    Jul 2015
    Dorr, michigan
    This is what I used
    https://www.amazon.com/Warm-Safe-Pan...085816&sr=8-11
    Feb 2016
    Quote Originally Posted by Fatcycledaddy View Post
    That is the ones I used also!
    Apr 2016
    Bloomington, Minnesota
    If you do it while you are doing an oil change, you'll save some work.
    indpls in
    im not sure power from back of alt is so good might be more voltage than gear can handle
    Oct 2020
    Mars, pa
    Just took delivery on 2020 limited. With the panel off to do oil change can you get wire from battery to area behind seat or mount the plug beside passenger grips?
    Sep 2020
    Middletown, NJ
    I put a powerlet outlet on the handlebar bracket from lamonster (swapped out their lighter socket) and routed to the right side then to the battery. When cold weather comes to the NE, I'll plug my heated gear into the powerlet.
    2020 RT base , Chalk White
    Sep 2018
    greensburg,pa
    Quote Originally Posted by fatboy View Post
    It's the same, the + cable is connected to battery and goes right to the back of the alternator.
    Same voltage period...................
    2018 RT-L , Blue
    Quote Originally Posted by bluewoo View Post
    True.... except that back in the day (well, at least back when I was learning about all this sorta stuff ) we were all taught NEVER to connect anything directly to the Alternator because even if it's fused, there's still a risk of a big enough wiring or device failure taking out the Alternator as well!!
    By connecting to the battery instead, the battery can act as a big fuse/an additional 'surge protector' for those 'less damaging' events and as a fail-safe 'protector of last resort' for any potentially more damaging events that might otherwise wipe out those more expensive and difficult to replace electrical components like the alternator.... And I'd guess that a heated jacket &/or trousers, gloves etc with lots of heated wires threaded thru them that have to withstand a heap of flexing & heat/cool cycles juuust might be prime contenders for causing one of those 'potentially more damaging events' in the event of anything ever breaking in all that threading!
    So for my 2 bob's worth, I'd be leaving the alternator connections strictly alone & connecting my heated clothing wiring directly to the battery via an otherwise isolated fuse block or circuit breaker that's well up to the task. But as always, when it comes to what YOU might do, it's ultimately your choice...
    indpls in
    my gear says to start bike before plugging in to protect it from any surge
    Mar 2013
    Maumelle, AR
    I brought my power up and zip tied it to my handlebar. Look closely and you can see it peeking out on the left side. I also use it for my battery tender.
    2020 RT Limited , Chalk
    Oct 2020
    Mars, pa
    Where is the alternator located?
    Jun 2011
    Near Lexington, NC
    Another easy place to put the wire from the battery is on left side of an F3 under the removable "instruction" panel. If you haven't noticed, there is a space above that panel that you can pull the wire out for attaching to heating gear or charger. I used a fairly hard wire to snake from that panel down towards the battery to pull the charger wire up. When not in use, simply shove the wire back under and its out of sight.
    I attach my Gerbing controller to the water bottle holder on the left side of handlebar which makes it easy to see/reach for controlling the heat.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
