Results 1 to 10 of 10
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Default Momentary rocker switch for 2020 RT
    I'm looking for a matching momentary rocker switch to fit the blank switch on the console of the 2020/2021 RT/RTL.
    I'd like to use it for my garage door opener. Anyone know where I could find one?
    2020 RT Limited , Petrol Blue
    Quote Originally Posted by Michaelscs View Post
    I've seen them on Amazon and E-bay .... try Bangood.com also ...........good luck .... Mike
    Feb 2020
    N. Wilkesboro, NC
    Search for threads started by jetfixer. He did just that.
    Mar 2013
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by PW2013STL View Post
    That's for a pre-2020+.
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by MONK View Post
    Thanks Monk! I'm not doing exactly what jetfixer did, but it led me to find a switch that matches. I'm just hiding my garage door opener under the plastic body panels and wiring it to the switch in the console.
    Feb 2020
    N. Wilkesboro, NC
    I get that, Michaelscs but in one of his threads, he mentions his source for the OEM (or damn close to OEM) switches.
    Sep 2015
    Cold Spring, MN
    That's why I thanked you. Like I said, your mention of his thread lead me to finding a matching switch. Read my post #6 again.
    Thanks again,
    Mike
    Danbury Connecticut
    Not the least expensive option, but it works pretty well for me. I bought an OEM windshield control switch and blocked out the windshield icon. I think it still looks OEM including the proper lighting at night.
    Others have less expensive options available. Here's my post.
    https://www.spyderlovers.com/forums/...=1#post1536484
    02 OEM switch installed.jpg03 OEM switch with lights.jpg04 Garage Door Opener location.jpg
    Here is another option, less expensive, but the switch isn't lit like the OEM one.
    https://www.foxtrot4x4.com/collectio...ge-door-opener
    F2155147-3CE3-4C91-A07E-EC6A4F4A1D2E_1_201_a_480x.jpgScreenShot2020-08-20at2.07.50PM_720x.jpg
    IBA #47122
    2020 RT Limited Asphalt Grey
    Oct 2011
    Jacksonville,Ar
    Thanks that is what I wanted
    15 rt , yes Black
