There is one on the right side. I have my Garmin 590LM GPS hooked up to it. It's only powered when the key is on.
Reason: Title - Circut
How about a little more detail. Which panels need to be removed for access. Any pics of location?
On the right side the first three panels need to come off. The first two pop right off. The third, has three screws and three pushpins. It's a little tricky until you understand how it comes off. Then it's easy. No pictures but I'll try to take a few.
I read on another post someone said there's one on the left side and it appears easier to get to.
Stebrock, send me a private message with your email address. I have instructions with pictures.
Bob H - Derry, NH
2020 Spyder RT Limited - Petrol Metallic Blue
2010 RT622 Trailer and BRP Hitch
BRP Vented Touring Windshield, BRP Backrest
Garmin 590 with BRP Mount
Fobo TPMS for Spyder and Trailer
Lidlox, Blue Sea Fuse Box for power distribution
Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
If those are instructions with pictures for the one on the left side, please send them to me, too.
His Facebook post is spot-on. Just did mine and used bullet/barrel connectors that you can get anywhere. Shrinkwrapped the connectors and then wrapped it up in some plastic for extra protection from water splashes. Used plenty of zip ties.
It is easier to fish the wire from the GPS from the handlebar area if you remove the speaker grille - it just pops out. If your hands are huge, you can even remove the speaker itself for more room.
Removing the 3 tupperware body panels is not a big deal - just don't force anything.
