Sure. Don't get carried away, though. I moved mine once, and it affected my transmission. I guess it was stretching a cable, or something. Also, When I raised mine, it resulted in terrible back pain. I was really surprised. I thought it would help.
Put mine as far forward as would the OEM allow. Love it. Better reach and I don't get cramps in my hands. I have 3T which means I moved the meat into the mirror field. Can't see anything unless I duck or stretch. I put a set of bar end mirrors on which I like a lot (they dampen vibrations).
u probably already know but just in case: make sure that all cables are easily moving while your moving handle bar - some of them are rather short and are tied really tight to handle bar and further down in bike and offer very little relief. Pulling them can break them loose from there end or handlebar connection.
2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
Loosening some may be as simple as removing a zip tie. You will see when you look closely.
OMG! Now BRP is cheaping out using twist ties instead of zip ties?? What's next, used tires?
Don't they come with used tires already? Less than 10 k on a rear tire is pitiful.
Actually a blessing in disguise. Now you can replace that "used tire" with a top notch one.
