Results 1 to 10 of 10
    May 2013
    New Jersey
    Default Warning light on
    I’m having a red exclamation point come on when I put on the parking brake , it seems to engage & disengage correctly. What I need to know does that mean I should call AAA to tow me home or is it just the parking brake.
    All help greatly appreciated
    T G
    2013rt limited
    Aug 2019
    southwest oHIo
    That light is simply telling you that your brake is ON.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Nov 2015
    Chardon, OH
    Is it on steady or flashing?
    Doug
    ”Freedom is not a loophole”
    RTM, pg 14-15.
    Florida Swamp
    Quote Originally Posted by Steve W. View Post
    Yep........ that is the parking brake on light.
    If you shut the engine off and don't set the parking brake, it will raise hell for about 10 seconds and scold you for shutting down without setting the parking brake.
    2019 F3-S , Black & Silver
    On my 2014 RT that light will come if the BRAKE fluid is low ( by a small amount ) if it's even lower the " brake failure " light will also come on ..... sometimes a tablespoon of fluid will fix the issue ..... Mike
    May 2013
    New Jersey
    Did not get the manual.
    Aug 2019
    southwest oHIo
    Quote Originally Posted by agasperino View Post
    Apparently your keyboard is faulty.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    You can download one here: http://www.operatorsguides.brp.com/I...1-018387e9aff0
    Just a reminder folks..........
    Rule #4 of the site rules: Don't Bypass site filters for swearing, black listed dealers or other links deemed unfit for the site.
    We want to keep this clean for all. Don't need "f" bombs (disguised or otherwise) tossed around. No infractions passed out (this time).
    Happy Labor Day.
