Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Sebring, FL
    My dealer responded to my email, they will order the kit and get it done when I come in for the 3K service.
  2. #27
    Sep 2018
    greensburg,pa
    I have a 2021 RT LTD on order and have an email out if this affects the 2021 model year also.
    2018 RT-L , Blue
  3. #28
    Active Member will's Avatar
    Mar 2012
    Harpers Ferry, WV
    Thanks, I trailered my 2020 Spyder to MN this summer and noticed that my mirror was looser after getting there. I will try the Lamonster solution.
    2020 Limited , Petrol Metallic
  4. #29
    Durham,Maine
    Quote Originally Posted by will View Post
    If it's still under warranty why wouldn't you go for the mirror fix from BRP, it free???
    2012 RTL , Pearl
  5. #30
    Sep 2018
    greensburg,pa
    Quote Originally Posted by bluewoo View Post
    iMotorsports states there not aware of this.
    2018 RT-L , Blue
  6. #31
    Danbury Connecticut
    There is a service bulletin out on these mirrors.
    BRP has the fix to bolt the mirrors in place and make them rock solid.
    My dealer is ordering the parts and will be installing them at no cost when they come in.
    I did the Lamonster fix, and finally got the bugs worked out, but if BRP has a better solution at no cost, I'm going with that.
    IBA #47122
    2020 RT Limited Asphalt Grey
  7. #32
    Mar 2013
    Maumelle, AR
    Do you have the name or number of the service bulletin? My dealer didn't know anything about it and opened a case for me. Waiting on a response. Although, I have Squared Away's fix and that took care of the problem.
    2020 RT Limited , Chalk
  8. #33
    Danbury Connecticut
    Quote Originally Posted by Copperman View Post
    https://www.carproblemzoo.com/tsb/ca...m-spyderrt.php
    IBA #47122
  9. #34
    Sebring, FL
    I contacted my dealer, he is ordering the BRP fix.
  10. #35
    Aug 2020
    Shenandoah Valley
    +1
    Did the same on Saturday.
  11. #36
    Apr 2020
    Westfield, IN
    You are absolutely correct, this should be a BRP fix without a charge back. It's going to be interesting the next time my '20 RTL goes in to get service.
  12. #37
    Dec 2020
    Hartwell, Ga
    Mine is still under warranty but I could purchase the kit from Lamonster and install it myself for less than it would have cost me to take it back to the dealer plus I would have lost at least a half a day doing it.
    Yes BRP has a fix for it at no cost but I do not know what their fix is. I do know that the Lamonster fix works.
  13. #38
    Sebring, FL
    Right Shooter, I did the Lamonster fix, it was easy and I knew it worked. I could have had my dealer do it, but I ride there 50 mins and back 50 mins and my tech said they had some returns on the BRP fix. I fact, my tech wanted the lamonster web site to order some kits.
