How do I pull fault codes?
my spyder just got the check engine light flashing and the limp home mode and a squiggly icon. this has happened before and it seems to go away on its own. I don't know how to pull the codes. I have a 2019 Can Am Spyder RTL. with 1330 motor. any help please?
Keep engine running when light comes on to pull current active code and follow the menu! If you turn it off that code may not be stored so just pull over and follow the menu.
https://photos.app.goo.gl/VcNsbGxAd3XawvjGA
![Quote](images/misc/quote_icon.png) Originally Posted by bluewoo
Good quick video on how to access the fault codes.
![](signaturepics/sigpic7798_4.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by trikermutha
the fault code it pull (C006C) now what do I do????
![Quote](images/misc/quote_icon.png) Originally Posted by ndspyderlover
Looks like
C006C ECM VCM error or failure reported Communication intermittent/erratic and/or Check Sum Error. May be triggered by U0122 (ECM) or U220B (ECM) or any VCM DTC Blown fuse External troubleshooting is not possible. Check for communication fault.
If you are still under warranty take it in before you may get stranded. JMO
Check fuses all in the left fuse box. Fuse F2 10 amp, J1 40 amp and J2 25 amp. Your owners manual will show you the location of the fuses.
