Page 32 of 44 FirstFirst ... 2228293031323334353642 ... LastLast
Results 776 to 800 of 1100
  1. #776
    Oct 2011
    Jacksonville,Ar
    Email Lamonster.com he may have your answers.
    15 rt , yes Black
  2. #777
    Quote Originally Posted by Jdr00ejr View Post
    Question 1: Where is the DESS physically located on a Spyder F3? Spent way too much time reading through this thread and didn't that anywhere?
    Question 2: Looks like Lamonster Garage at 500 miles is the closest to Indianapolis who can disable the DESS. Anyone else closer?
    Question 3: Once it does the complete failure thing - can you trailer the bike to someone to disable it - or do you need to get a good key read first to disable it?
    #1. - I have a pic of EXACTLY where it's located on an RT .........
    #2. - ???? .......
    #3.- I think it has to be functioning .....
    #4. - If it fails .... turn ignition on/off 5 times rapidly .... that worked for me ..... Mike
  3. #778
    Vermont
    Question 1. I am not sure wear the DESS module is located on F3 spyder.
    Question 2. Email Lamonster Garage and ask them if there is anyone closer or have them disable the DESS.
    Question 3. Email Lamonster Garage for that answer.
    What year is your F3 spyder?
    Do you still have warranty/or B.E.S.T coverage on the spyder?
    If you still have warranty /or B.E.S.T coverage on your spyder make an appointment with your can am dealership, have them open up a case with BRP and make sure that your can am dealership has the parts. Have your can am dealership run it thru the warranty or B.E.S.T.
    Hope this helps.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  4. #779
    Apr 2016
    Council Bluffs, IA
    2014 RTL I get the DESS error every once in awhile. I'll go a couple of months without one, then it'll pop up two or three days in a row. No rhyme or reason at all. Most of the time when it hits, I'll just turn off the key, and quickly turn it back on. Wet or dry, hot or cold, it doesn't matter. Never been stranded because of it, knock on wood!!
    2014 RTL , Gray
  5. #780
    Quote Originally Posted by Bill W. View Post
    Once the DESS code appears ..... it is only a matter of time to When it WILL FAIL not IF it will fail. This part will not Heal itself .... and nothing you do will get the Spyder re-started - Period. ... 99.9 % of these DESS issues began in 2014 after some Dumb A** engineer decided to fix a part that wasn't Broken. Then they started to have issues, and it took a couple of years for BRP to get that part to function with better reliability. So if stay close to home and near a dealer and hope it takes less than 3 weeks to get it fixed, then don't worry about it ..... good luck .... Mike
  6. #781
    Durham,Maine
    If my ride had that problem ,It would be gutted out of my bike as fast as I could!! There always some one trying to reinventing the wheel and screwing it up with a flat side!!!!
    2012 RTL , Pearl
  7. #782
    Mar 2015
    Indianapolis, IN
    Question 1 I am not sure wear the DESS module is located on F3 spyder.
    Question 2 Email Lamonster Garage and ask them if there is anyone closer or have them disable the DESS.
    Question 3 Email Lamonster Garage for that answer.
    Hope this helps.
    Deanna
    It's a 2015 F3S - it's not under warranty - which doesn't concern me because I do my own work anyway. Sometimes the homework to find the answers is harder than others though.
    I laugh every time someone posts "just email Lamonster Garage for the answer" because I have already - with ZERO response. Which I've experienced several times before. I'll find a different source to answer my questions.
    Joshua
    2016 Spyder F3S
    2019 Spyder RT Limited
    2022 Ryker Rally
    2016 F3S , Triple Black
  8. #783
    I have posted dozens of Answers about the DESS issue over the years, and some of them to your questions ..... good luck .... Mike
  9. #784
    Mar 2015
    Indianapolis, IN
    Mike - My response wasn't an attack on anyone here. Sorry if it came across that way. There's a wealth of knowledge in this thread (and others) and I've gleaned a ton form it - you replied to my questions above - but still left me with unanswered questions. I appreciate the input you did offer. I was just pointing out that many folks around here say just email Lamonster (not saying you said that) and the fact is, the few times I have, I've not gotten a response back from Lamonster. They have great products, and I may end up going out there for service (disable the DESS) - I'm just saying - I tried them - before asking here - and didn't get a response - which is why I asked here (a different source).
    No ill intent meant. Have a great day!
    Joshua
    2016 Spyder F3S
    2022 Ryker Rally
  10. #785
    My post #804 had No ill-intent either ! .... It was simply a statement ... no agenda ... no hidden meaning. I try to provide accurate , informative knowledge that I have acquired. .... I receive 100's of PM's and if I can assist, I do .... If I can't, I try and send them to someone who I'm pretty sure does have accurate info...... Have a better day ................... Mike
  11. #786
    Houston
    Question 1: Where is the DESS physically located on a Spyder F3? Spent way too much time reading through this post and didn't that anywhere?
    Question 3: Once it does it's complete failure - can you trailer the bike to someone to disable it - or do you need to get a good key read first to disable it?
    DESS module is on the frame near the battery. Service manual will show you how to access.
    i do not know of anyone closer to Indianapolis that Lamont or Spyderpops.
    Yes, if the DESS fails completely, it can still be disabled as long as you have the physical key to unlock the ignition and apply power to the ECM and instruments.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  12. #787
    Mar 2015
    Indianapolis, IN
    Thank you, thank you, thank you!
    Joshua
    2016 Spyder F3S
    2022 Ryker Rally
  13. #788
    Aug 2019
    Battle Creek, Michigan
    I too have left 4 or 5 email messages at different times with LaMonster and have never received a response yet. Even called a couple times and left a phone message and didn't get a call back, but I have called other times and was able to talk to someone and place my order. I guess they are pretty busy, especially this time of year.
  14. #789
    Vermont
    HI Jdr00ejr:
    Sorry for getting back to late "Life got in the way".
    Sorry, Good luck finding your answers.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  15. #790
    Vermont
    Bump
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  16. #791
    Vermont
    Bump
    This thread has a lot of excellent info.
    As of today I haven't had the D.E.S.S issue.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #792
    Sep 2014
    USA
    I recently replaced the antenna on mine since the module was replace twice. Last year the DESS key popped up again. So since the Spyder was down for something else it was time to change the antenna. Now if it happens again. It will be disabled thru buds.
  18. #793
    SoFlo
    Deleted
  19. #794
    SoFlo
    Deleted
  20. #795
    Vermont
    Considering DESS is typically a 2014 to 2016 concern, but might occasionally affect other years, not likely owners will have the issues like in the past.
    Since your DESS remains active, may be safer to not tempt Karma and discuss having no failures.
    PMK,
    Sorry I "Bumped this thread.
    I wont bump this thread any more. Or I can/or have this thread closed!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  21. #796
    SoFlo
    Deleted
  22. #797
    PMK,
    Deanna
    I wouldn't worry too much about closing the thread Deanna, this DESS thing does still come up every now and then, and probably will continue to do so until either every 2014-2016 Spyder ever made has had their DESS disabled; or BRP issues a voluntary recall to fix the problem at their expense And since I don't see the mob in that hot place down below looking to buy themselves ice skates anytime soon.... there's probably a valid reason to leave this thread active for some time to come!
    Same with bumping it - it doesn't really hurt anyone to have the thread brought back to the top of the recent posts list every now and then, and who knows, it MIGHT actually help someone - just look at trikermutha's recent post some 9 months after your bump last year, and very likely only there as a result of your May this year bump reminding him the thread was here! So go ahead, bump away - just not weekly or even monthly please - not unless you've got something more to tell us! In fact, don't do it too often without actually adding something substantial please! Personally, I reckon a thread that's full of nothing more than pages on pages of 'bump' posts or similarly pointless 'empty posts' is actually worse than useless, cos all it does is tell readers the OP doesn't really care &/or have anything new to offer/tell us, but wants to stick it to us anyway - bleedin' worse than unsolicited 'cold callers' or junk mail/spam filling your inbox (or letter box, for those of us who still have them!) But if there's an update on how things stand now; or even just info on how many people have approached you about how you resolved your DESS problems or something/anything like that - it only hasta be a snippet of worth while info, then the knowledge base is still growing and you are very likely helping by bumping the thread and keeping us all up to date on the current state of play!
    Over to you!
  23. #798
    Sep 2014
    USA
    As long as there is still the 2014 _ 16 models on the road keep it open till it runs its course. Most cases the module takes care of the issue. In mine it did not . The bulletin says don't replace the ignition switch just the antenna if the module didn't take care of it. So that's what I did. I preferred to keep the security feature at this time.
  24. #799
    Vermont
    Relax, I stated facts that DESS concerns is less applicable now than back then and you launch to close the topic. Entirely your call. Lot of drama over no big deal, take a breath and unwind.
    PMK,
    I am not closing this thread. Sorry!
    I am going to let this thread run it's coarse.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #800
    Vermont
    Over to you!
    Peter Aawen,
    I'll only bump this thread if I have any new info or once a month as a reminder to everyone.
    I'll also keep this thread open.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
