Results 1 to 8 of 8
    Jun 2020
    Maryland
    Default Sercurity? The best way lock the F3
    While at home and before I get garage, or a trailer to store it.
    Whast is t he best to secure them
    Chain threw the wheel etc.....
    Thank you
    Jun 2014
    Schenevus NY
    Quote Originally Posted by Mcolabella View Post
    Thank you
    You can lock the handlebars by turning them all the way to the left, then turning your key to the left (without pushing it in) to the lock position. Remove the key and your handlebars are locked.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Feb 2019
    Portland, Oregon
    A full cover helps to keep prying eyes away.
    Mar 2017
    temporary garage works good along with locks mentioned above.
    https://www.harborfreight.com/10-ft-...age-62860.html
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    I use a 'disclock' on the back wheel - abus 'Granit':
    Fits nicely through the slots between the rear disc and it's mounting bracket. I can take a picture if you're interested.
    Insurance in the UK often insists on a 'visible deterrent' to get theft cover. Not sure if these are widely used in the US or more of a European thing?
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Cover to keep out of sight and if you can lock it up. If thief has the time they will find a way -- but at least they will have to work at it.
    Joe
    2023 F3
    Jun 2020
    Maryland
    Quote Originally Posted by monkeyboymorton View Post
    Thanks can you share a photo of it on your ride
    Mar 2017
    Honestly, the best theft device is the Can AM BRP logo along with the D.E.S.S. key system. The Harley parked next to you is more the likely target for theft. Easier to load onto a trailer and more of a profit point for the thieves.
