Results 1 to 23 of 23
    Jun 2020
    LA
    Default F3 Limited - Rear Panel for LinQ
    >> UPDATE - Just saw an old post with some speculation but no definitive answer. <<
    Hi all,
    Sorry if this has been asked previously, for anyone who has purchased or looked into the 2020 F3 Limited - Do you know if there is a Rear Panel for purchase, either as an OEM or third party? I thought perhaps the LinQ system was to create some universal parts but now I see that all the system is for is quick release. It would be nice when soloing or just going around the area, the top case could be removed with a nice cover to replace it.
    I asked my local dealer and they no idea, couldn't find anything from BRP.
    Thanks!
    RJ
    Harrington, Australia
    Yes, there is a colour coordinated cover shown in several of the 2020 CanAm walk around videos, RJ. Hop on to YouTube and do a search for 2020RT walk around (Or similar)..... you lift off the trunk, and pop on the cover.
    HeliBars Handlebars
    Kenda Kanine rear.
    Found it...... removal at 2:15.
    https://youtu.be/eLWM1Fp4eNw
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2020
    LA
    @Peteoz thank you so much, I had to edit my post to a typo. This is for the F3 Limited not RT.
    Quote Originally Posted by diverd View Post
    I’ll check a couple of other videos I have, but I can’t imagine they wouldn’t have a cover for the F3 as well, RJ.
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2017
    Active Member Tec35's Avatar
    Dec 2019
    Rhode Island
    This is the part number 708302912 the rear cover of an F3T only comes in black this is the best I could find on brp oem parts. You can find it under body and cargo accessories.
    https://can-am.brp.com/on-road/us/en...ts-iframe.html
    2017 F3 limited , Black
    Jul 2010
    Las Vegas, NV
    I have one in black. Pm if interested. Joe
    Joe Meyer
    Feb 2020
    N. Wilkesboro, NC
    Are all 2020 F3Ts LinQ compliant?
    Jun 2020
    LA
    Thank you everyone for the research and help!
    Quote Originally Posted by Rattlebars View Post
    Yeah, but that is for the 2017, not the 2020 with the LinQ system, Rattlebars.
    HeliBars Handlebars
    Kenda Kanine rear.
    Did you see Joe’s definitive post above, RJ?
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2017
    I thot it was the 2020. Musta copied the wrong link
    https://www.youtube.com/watch?v=eLWM1Fp4eNw&t=2m10s
    Jul 2013
    Piedmont, SD (Black Hills)
    I looked at doing that on mine... I think all it might take is removing the topcase and then also removing the LinQ bracket. I put a topcase on my wifes F3T and the places that the cover would go are all still there but whether the old style or the LinQ style, the topcase bracket would need to be removed to put a cover on..
    Feb 2021
    Maryland
    Was there a solution? I'm looking for a rear panel for a 2021 F3-L. I can't seem to find anything
    Quote Originally Posted by MONK View Post
    The 2020 F3L we just purchased (mfg. in 1/2020) came with the link system. The trunk is much different than the one on our 2019 F3L.
    I am guessing that these are the same trunks that are showing up on the 2020/21 RTL's. I was thinking of getting one of those covers and would like to take the trunk off for the "T" look, which I like.
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    Quote Originally Posted by Showbiz View Post
    I think this is it.
    https://www.cheapcycleparts.com/oemp...k-rear-fairing
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Member JBMGDM's Avatar
    Apr 2021
    Dallas, TX
    Just purchased a 2021 F3 Limited and wanting to do the same thing. Did https://www.cheapcycleparts.com/oemp...k-rear-fairing fit the bill?
    2021 F3 Limited , Metallic Black
    Apr 2021
    Dallas, TX
    Default Found this on FB
    Quote Originally Posted by JBMGDM View Post
    Found this on FB...
    https://www.foxbrpparts.com/oemparts...n2X4Y4aCIhnvm8
    Jan 2021
    northeast pa.
    looks like were getting to the bottom of this.. panel looks right, how many clips , how many rivets.. hummm thanks
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Member 2katz's Avatar
    Jul 2021
    Spring (Houston), TX
    Did anyone come up with the correct part(s) to remove the top box and replace with a panel on the 21’ F3L?
    2021 F3L Black/Chrome
    LAMonster:
    Ultimate Backrest, Bottle Holder, Baja Ron Sway bar, Cat Delete Pipe, Freedom Windshield, Highway brackets/Black Demond pegs, Upgraded Tension Roller, FOBO Tire Pressure Monitor
    TricLED:
    Sequential LED Spyder Fender Lights, Run/Brake/Turn Strobe Light Kit, Brake flasher
    SlingMods:
    Chrome Luggage Rack
    Pedal Commander
    Spyder Accessories.com:
    Tank Pad
    Amazon:
    Ciro phone holder/mount, Stebel Nautilus Air Horn/Wiring Kit, Short Reach Handlebar
    Jan 2021
    northeast pa.
    I was at my dealer Tuesday for inspection, they had an F3L there missing the topcase, I asked parts guy if they made a cover, he said yes, black only - he looked it up on parts list... He said it was like $190.00 and would need push pins also, so around $200.00 or so... that's all I know.
    grip puppies
    Bajaron sway bar
    battery tender
    Quadtrac 165/60's
    Jul 2021
    Thanks. I’ll reach out to get the scoop.
    LAMonster:
    TricLED:
    SlingMods:
    Chrome Luggage Rack
    Pedal Commander
    Tank Pad
    Amazon:
Tags for this Thread
