Results 1 to 5 of 5
    Aug 2019
    AR
    Default Buzzing at braking
    I have a 2012 RTS with 7,500 miles on it. When I brake from speeds over 35 I hear a pronounce buzzing sound. What is causing this and how to fix?
    Check ALL your brake pads for wear, it could just be that they are getting down a bit!
    It can also be the ABS system which can make a somewhat subtle buzzing noise at slower speeds. Most of the time it isn't noticable.
    Sep 2012
    Stetson, Maine
    ABS is what it sounds like to me. Mine will do it.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    SoFlo
    Did you recently replace the brake pads? Our 2014 was pretty quiet, but after installing new brake pads, and I did not chamfer the edge of the brake pads, there is a very noticeable buzzing sound when the brakes are applied.
