Results 1 to 17 of 17
Thread: HMC filter
    Mar 2015
    forrest above Reno, Nv
    Question HMC filter
    I'm going to be replacing the tranny filter soon and have a question. Owners manual says to activate system to relieve air (in the filter chamber????). Is this necessary?? Seems like one could R and R --- refill the oil and start to motor to let it fill and release any trapped air.
    Any help is much appreciated.
    Lew L
    Edit: That would be the HCM filter.
    2014 RTS , Circuit Yellow
    Sep 2014
    USA
    Never did activate with BUDS. I installed and started the bike. No issues.
    Mar 2015
    Thanks Triker.
    I've sold several hundred of the SE6 HCM filters. No one has done the BUDS procedure. No one has had any issues. As with any oil service. Fill with oil, start and let idle (do not rev up the engine) so that the system has time to fill all cavities before any load is introduced. It will work just fine.
    I did not use B.U.D.S. when I changed my HCM filter at 56K service; no problem.
    Mar 2015
    Thanks gentlemen.
    Sep 2016
    Chillicothe, Oh.
    As the others have done I changed mine at the last oil/filter change. No Buds, except for the couple I drank.
    2015 RT , Black
    Jul 2016
    New Hampshire
    Is there a video of changing the HCM filter and what are the torque amount for the filter bolts?
    Dec 2012
    Murphy, NC
    I don’t know about a video for the HCM filter but just tighten the bolts snug and don’t worry about torquing. Same goes for the oil plugs. Just tighten them snug and you will be OK.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Mar 2015
    Received the filter today and will install it at the next oil change before winter.
    Quote Originally Posted by SPYDER-NH View Post
    As with any part that seals with an O-Ring or rubber edge seal (as in the case with the 1330 HCM filter). It is most important that you tighten each fastener a little at a time so that you get equal and even pressure all the way around the seal perimeter. Just snug is sufficient as it is the rubber seal that is doing the work. Over-tightening is to be avoided. It is unnecessary and counter productive. I like to use a stubby 3/8" ratchet. This gives you a great feel for how tight each fastener is. And helps to keep from over-tightening.
    Feb 2012
    Spring City,Utah
    And while tightening use a crosshatch pattern.this will ensure you dont go too far on one side while tightening.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Here's the tightening sequence and torque spec. Notice it's inlb.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    didnt see this thread. was also asking about a video. some good info.
    [joyce & irvin toms]
    Jun 2014
    Schenevus NY
    If your torque wrench has calibrations for newton/meters use that. It tends to be more accurate.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Feb 2014
    Atlanta, GA area
    Hello JayBros,
    When you replace HCM filter, 1) do you need to use gasket sealer when you install the replacement cover-filter assembly? and 2) do you know what torque to use on the HCM bolts?
    Semper Fi, PatrickH
    2014 Spyder RT LTD silver, Corbin saddle w/backrest & gas filler door, 4" stubby antenna, dual USB charging receptacle on dash, handlebar "cuff" attachment point for RAM phone mount, Diamond-R trunk-top level luggage rack, magic mirrors, Bestem saddle bag liners & Hopnel trunk bag (2-piece set), SpyderPops bumpskid (not lighted), highway foot rests; rear tire General Altimax 215/60/15, Baker Wind Wings, LED Headlights, RT Series 2010-2019 Rear Trunk Holder
    Feb 2014
    Atlanta, GA area
    JayBros,
    Sorry for the question abt torque spec. I see you'd already posted that info.
    PatrickH
