Page 12 of 78 FirstFirst ... 289101112131415162262 ... LastLast
Results 276 to 300 of 1927
  1. #276
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Hit 40K today.
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
  2. #277
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Quote Originally Posted by ARNIE R View Post
    Hit 40K today.
    Wow, your bike idles high.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  3. #278
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    Quote Originally Posted by Peacekeeper6 View Post
    I think the V-twins idle a little higher than the triples.
    2014 RTS , Circuit Yellow
  4. #279
    Dec 2011
    AC N.J
    gave it a bath
  5. #280
    Wa.
    Ordered some farkles from Canamspyderaccessories yesterday. Be here soon so I can install them.
  6. #281
    Feb 2019
    Portland, Oregon
    I did Lamont's wobbly mirror fix and it works great. They are now rock solid. The job would be a lot easier with the bike on a lift - the two screws on the bottom of the turn signal are very difficult to get to without standing on your head. I see why those two lower screws were missing on the one Lamont was demonstrating on for us. He was surprised - I'm not!
    BE ADVISED......Although 1/4-20 X 1/2" screws were recommended by Lamont, one side was still not tight enough and I had to use a slightly longer one. Also, I did not run the tap all the up the shank. I stopped when a bit of the tapers tip appeared, making for a tighter fit for the screw...and I applied some blue Loctite to the threads, just for giggles.
  7. #282
    Mar 2015
    Thumbs up Brake pads
    Got my brake pads and bought the special grease to make sure they slide right and the quieting compound to keep them --- ah---- quiet.
  8. #283
    Feb 2019
    Portland, Oregon
    My Ultimate saddle arrived! It dropped into place so easily, I didn't think it was secured. The original rider's seat was very difficult to attach - a real fight. Then you hope the bolts to secure it didn't disappear into oblivion. It's a Tall Boy and boy howdy, I needed that inch it moves me back. Thanks Timmb, you cared well for it and packed it so nicely that it made the trip across this continent unharmed.
  9. #284
    Sep 2019
    Reno, NV
    Rode her to work.
    Wow, those Baja Ron swaybars are wicked good !! No wonder so many people rave about them. I think with nicer front tires and a laser alignment, it’s going to be light years ahead of stock in terms of handling and performance.
    Digging the Utopia back rest as well. WAY more comfy in the saddle !!
    Might have to slow down on the farkling the next few months.
    (With the emphasis on “might”, lol).
    2002 BMW 325i - his
  10. #285
    Danbury Connecticut
    Here's what I did today:
    I had a pretty bad mirror shake on the left (most important) mirror.'
    I used Lamonster's fix. Great idea. The only difference, I had to buy a two piece drill and tap set to cut the thread, as opposed to the one piece that Lamont has.
    IBA #47122
    2020 RT Limited Asphalt Grey
  11. #286
    Mar 2015
    Installed rear brake pads. Held the ( and pumped ) the brake pedal for 30 sec or so. Turned on the ignition key---- No brake lights
    Yes Lou--- the upgraded anti-sway bar is GREAT.
    Lew L
  12. #287
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    Dropped it off at the dealership to get the oil changed, a handlebar riser installed and a headlight fixed.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
  13. #288
    Feb 2019
    Portland, Oregon
    That's what most of us have; a drill bit set and a set of taps and dies. Harbor Freight has a coupon for a big drill bit set for under $11. Their tap and die sets are reasonable too and good enough for the home DIYer. Get one with both SAE and metric size taps and dies.
  14. #289
    Jan 2019
    Hunter Valley NSW Australia
    Not quite today but two weeks ago, fitted two Baja Designs S2 Pro Mixed Lens driving lights. OMFG.
    I had hooked them to a battery to test them once before and thought they seemed pretty good, but once I had them wired in by the dealership, and made the 200km ride home that night, they are amazing. They are light, have the option of Spots, Spreads or both and weigh very very little. They wired them to a separate switch so they have to be operated separately to the High beam, but that isn't an issue, when the S2's are on and you flick to High Beam it adds nothing to the amount of light out front.
    I saw a guy buy a selection of LED bars and lights and do a comparison on youtube. These were almost as good as some of the much higher priced light bars.
    The down side - when you hit oncoming traffic and have to drop to low beam you realize just how candle like the low beams on the Aussie models are.
    2017 RTL , White
  15. #290
    Wa.
    Cleaned an waxed my spyder this morning. Got bugs all over the front. Them bugs are getting nasty out there now.
  16. #291
    Nov 2018
    Claremore, Ok.
    I rode it for about 650 miles in two days in 105 degree heat. I got toasted, and not in the good way.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
  17. #292
    Mar 2013
    Did the Lamount mirror fix on my new 2020 RTL.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  18. #293
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by PW2013STL View Post
    Pretty neat fix, isn't it PW?
  19. #294
    Aug 2018
    North Georgia
    Well we did what we’re supposed to do... took them out and RODE them! Not far, maybe 45 miles round trip but we did get to try out the new helmets and intercoms and had some fun before it was time to come home.
    2018 F3S , Black
  20. #295
    Mar 2013
    Quick and clean!
  21. #296
    Nov 2017
    San Francisco Bay area
    Oil change and put in led’s for the head lights.
    Next up magic mirrors, and fender lights with blinkers
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
  22. #297
    Vermont
    Quote Originally Posted by LeftCoast View Post
    You will like the magic mirrors, and the fender lights.
    I have the magic mirrors and the fender lights( Amber on the side, and red on the lower part near the Can -Am silver piece).
    I have not had any trouble with magic mirrors. We have some very rough roads here in Vermont.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  23. #298
    Vermont
    Yesterday ,I washed the spyder. First wash since April( after hibernation).
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  24. #299
    Feb 2020
    N. Wilkesboro, NC
    Rode about 75 miles. (It's too hot.) After I got home and cooled off a bit, I installed Lamonsters Longhorn LED mirror lights. I think I've taken the front tupperware off enough I can do it in my sleep.
  25. #300
    Sep 2015
    Chilliwack, BC. Canada
    Didn’t do much, too wet to go for a ride, but I was able to pair my TomTom 550 with my Cavalry helmet. I spent a lot of time conversing with Dave (MotorcycleDave) about the different Sena units, the Dongle (SM10) vs the Sena FreeWire used by the Goldwings and the HD’s. Thanks Dave, very helpful indeed.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
