Results 1 to 13 of 13
    Denver
    Default Orange Exclamation Point
    Does anyone know what the Orange Exclamation point on the dash means? I have a 2018 RTL and yesterday it came one while stopped. It went away and I haven't seen it since. The manual only says :Orange- Vehicle Malfunction but does not explain it.
    You can pull up the codes easily.
    Go into all of those screens on the RH side of your display, and find the one for Codes.
    NOTE: if the problem was intermittent; nothing will show up. It'll only display active codes...
    Default Well....
    Seems to be a parking brake warning light. If you don't have the spydercode app you should download it and it will help your with all those lights, codes, and much more. Great tool to have on hand....
    Denver
    There was no code displayed when I looked as described as I pulled over when I noticed the light. Does spydercodes say what that means? Although the developer makes a great app, I do not want to spend 15.99 for another vague description of the light. The other vague description is the owners manual. The parking brake was not on nor being engaged. I was sitting at a stop light when I noticed it and as I drove it turned off.
    thanks
    Nov 2015
    Chardon, OH
    Quote Originally Posted by maxxheadroom View Post
    thanks
    Was just leafing though your manual. If you are talking about receiving the indicator lamp described on Page 31, that's a general message and is usually accompanied by a safety / informational message as shown on Pages 138 and 139. Easily missed if the message happens to be off at the time. Based on the behavior that you described, I'd look at brake fluid level.
    Doug
    ”Freedom is not a loophole”
    Sep 2016
    clark county indiana
    Default if it pops up
    if this pops up again , and you can safely take a photo , it is a whole lot easier to under stand what the situation might be , ( orange , could it be you are not shifting correctly ? )
    Denver
    Thanks for the info.
    Denver
    This is the warning light I got. From page 31 of the manual it just says Orange - Vehicle Malfunction. It is not the Red with a circle for breaks, just the Exclamation Point. It is the first warning light on the left of the New display on the 18's. If you have the new manual look on page 30 of the black display and you will see the warning light I am talking about on the graphic of the LCD display. There were no other Indicator lamps or messages as described on pages 138 and 139. Thanks again. I am just curious what vehicle malfunction is supposed to indicate.
    I'll bet you forgot to read the Safety Warning Placard...
    Apr 2014
    NE O-H-I-O
    I got that icon twice now with limp mode indicator. I’m fairly certain I invoked both instances bynot pressing the start button squarely enough (I was standing next to bike and thumb was off at angle. Anyway, both times I shut the engine off and restarted making sure I pressed the start button more squarely/positively. Maybe a hiccup?
    Aug 2018
    Vancouver, WA
    Here's the answer: https://can-am.brp.com/spyder/technologies/display-technology.html
    What is the purpose of the new “!” icon?
    All vehicle malfunctions that are not engine related (i.e.: suspension, power steering) will use this new icon instead of the check engine icon.
    Denver
    Awesome... thank you for that info.
    Apr 2016
    Bloomington, Minnesota
    Mine came on when I went two up with fairly heavy individual, so I think mine was a suspension complaint.
