Help wanted - Tow F3 with my RV
Hi everyone,
My English is not so good, but I will try the best I can.
I live in Amsterdam (Netherlands) and I want to tow my F3 with my RV (Motorhome).
I dont want a trailer because of the space it will take when we are at home.
I found this:
https://motorcycle-rack.com/CanAm_Tow_System.html
Did anyone used it?
Is it good? Does it work well?
Is it safe?
I love it, because it is small and it looks very easy to install.
But maybe I can use a tow-bar to?
The one that people use to tow cars behind their RV...
Looking forward to see you reactions.
Regards Rob
Go over any sort of bump or anywhere that will cause the hitch point to rise up and it will grind the nose off the spyder. These bikes are low enough in the front to begin with and when you jack the rear wheel up, it lowers the nose down to probably an inch or less from the ground. Not good. Get a trailer for the bike or dont do it at all.
2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
I would not tow my F3L like that.
I would not use that device to tow any Spyder. Eviltwin is correct in every respect. Furthermore, you should not consider towing a Spyder using a tow bar that holds the front wheels because you could damage the transmission unless you remove the belt from the rear wheel and that would be a nuisance having to remove the wheel every time you wanted to tow the roadster.
Ozzie Ozzie Ozzie
I have not used one for a Spyder, but I have used one on a two-wheeled cycle.
ONCE.
Never again.
IF you choose to use the one in the link and hold the rear wheel off the ground, remember that the farther you lift it off the ground, the closer your 'chin' will be at the other end. If you only lift it a minimal amount, there is a chance that it (the hitch) will drag when going into a driveway if the front of the RV goes up.
Then, even if you happen to find a 'happy' height where neither end drags, how do you plan on holding the handlebars so the wheels stay locked into a "straight-ahead" position?
The alignment presumes that the Spyder will be going forward, and will self-center to go straight. Turn the bike around, ... no telling which way it will go, unless restrained.
I wouldn't be against something like this. Simple, no trailer or dragging the Spyder around..
https://hydralift-usa.com/canam-spyder/
Reason: edit
