Results 1 to 12 of 12
Thread: drink holder
    Mar 2020
    SE Wisconsin
    Default drink holder
    What does everyone use for a Passenger drink holder
    I have a 19' RTL
    Sep 2018
    greensburg,pa
    I have this and it holds a good load as my wife has a very heavy water thermos. Just make sure it doesn't twist down or it will damage the paint.
    I kept adjusting it till it was just right.
    https://www.lamonstergarage.com/can-...cle-lamonster/
    2018 RT-L , Blue
    Jul 2018
    Fountain Hills,AZ
    Butler cup..I used it on my Goldwing now on my RT keeps water cold ALL day long!!!
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by bluewoo View Post
    2015 RT , Black
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    The best cupholder would depend on the cup/mug/bottle you want to use. We use 20 or 24oz Bubba Hero Sport bottles, on sunny 95° days I've filled them up with water and 5 ice cubes and they will go gas stop to gas stop and still have ice. Usually run out of drink before the ice melts. Only thing is the bottles are large,and I had to make my own holders out of PVC pipe and webbing. To attach to the passenger grab handles I did as bluewoo posetd, but I put a RAM ball on the holder itself and used a medium arm to keep it away from the tupperware.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Mar 2019
    NEBRASKA
    Drink 2go front and rear.
    2012 RTL 14 RTS , Pearl White @ Pearl White
    May 2018
    Jacksonville, Florida
    Drink2go.com They work very well for the front and back.
    Thank you,
    Ray B.
    These are the states I have driven my Spyder Rt Limited too.
    Mudflap -- Walmart
    Tricled Headlights and Fog lights -- valueaccessories.comRimsavers -- RimBladesUSA.com
    Showchrome Tiregard (TPMS) -- motorcycleid.com
    Front and side grilles -- CanAmSpyderAccessories
    Passenger arm rest -- Diamond R Accessories
    Rear axle caps -- Lamonster
    Magic Mirrors -- Lamonster
    Yellow and red running and blinker lights on fender --Show Chrome
    TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
    Rear Brake light for trunk -- Custom Dynamics
    Bumpskid w/led lights -- Spyderpops
    Seat cushion -- Airhawk
    Cup holders -- Drink2Go
    Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
    We bought some Diamond R cups at the last rally we were at. When I traded out the 2011, it transferred with no problems to my 19 F3.
    I note you are posting about the new 20. Just go to any of the above, and they should now say if they are compatible with the 20.
    May 2016
    Sun City West, AZ
    Where did you mount it on your spyder
    SoFlo
    Our Spyder has Corbin Armrests for the passenger. They came with the Corbin cupholder. The Corbin cupholder did not work well.
    Removed the Corbin cupholder and installed a Profile brand bicycle water bottle cage. This works very well for us. Typically placing a clear drinking water bottle in the holder. Even though loose, they have never been lost. The Corbin was bad about loosing entire water bottles.
    Mar 2020
    SE Wisconsin
    My wife got a Bear Claw from her son for her B-Day!!!
    It seems like it will work for her
    Thanks for all your inputs
    Active Member triplethreat's Avatar
    Feb 2020
    "Murvil", TN
    I also use the Drink2Go for the passenger cup holder. Up front, I've got a LAmonster Spyder cuff with the cup holder on the back side. I already had an insulated cup that would fit, so I didn't purchase that.....every works great.....front and rear.
