2011 Can Am Spyder Rt Limited stalls
I have a a 2011 Can Am Spyder Rt Limited with 9400 miles. More than a few times as I am coming to a stop and the bike is downshifting as it shifts from 2nd gear to 1st the bike stalls. This has happened 6 -7 times in the last couple rides. Any help or suggestions ? Thanks
Welcome to the forum Jimbombeck. I would look and make sure your oil level is good and have you changed the oil and filters (transmission & reg. oil filter). Do that if you have not. Next thing is the two small vacuum lines at the bottom of the throttle bodies. do a search here for that and you will see many treads on that subject.
My Spyder ![](signaturepics/sigpic32694_1.gif)
No error code... suggestions?
![Quote](images/misc/quote_icon.png) Originally Posted by jimbombeck
Just the oil & filters (transmission filer & oil filter) how old are they? The year of the Spyder strongly suggest vacuum lines may be a problem or drying out and cracking. see the link I gave you above and search for more info if you like. With out more info then you have provided that would be where I would look. With the vacuum lines sometime you don't see error codes.
Replace the vacuum lines, cheap easy fix. It fixed my 2012 stalling problem.
