In 2014 an engineer ( and in this case I use the term loosely ) changed the DESS module ..... that's exactly when the problem began, prior to then I hadn't heard much in the way of complaints about Failure ..... Canceling the DESS won't speed up the start delay .... at least it didn't change mine when I had my DESS canceled ...... Mike
