Question: Does the "1330" triple engine need a??
HI All,
During this pandemic (Covid-19) does the "1330" triple engine need to be put on a battery charger/maintainer?
Since people are in a "Stay Home, Stay Safe/or Lock Down orders per there governors in there states & since people are not riding as much as normal.
I am just putting this out there, because of the current pandemic.
Under normal circumstances I wouldn't do that.
I have a 2014 RTS-SE6.
I am only looking for suggestions or ideas. Also trying help other spyder riders on this site.
Everyone stay safe, healthy, wash hands, wear masks, practice social distancing, stay home. We will get thru this!
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
A Battery Tender sure won't hurt!
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
Battery ...CHARGERS ... are different from Maintainers ..... read the directions on each and use accordingly ...... If I'm not actually riding my 14 RT it's on the maintainer .... I would only use a CHARGER, ( that has a meter built in ) to bring a battery up to FULL charge , then dis-connect and use a maintainer ..... A CHARGER can FRY a battery .... even the 1 Amp type / size ..... good luck ... Mike
![Quote](images/misc/quote_icon.png) Originally Posted by Deanna777
HI All,
Deanna
I know you had mentioned somewhere that your spyder was soon coming out of winter shutdown. I am guessing that you do have a battery tender hooked up for that.
When we moved from AK to AR, it took over 70 days for the furniture and bikes to arrive. All three bikes were put on a truck with no battery tenders attached. All three started up first try. I am thinking you will be OK for the rest of the duration.
![](signaturepics/sigpic4721_5.gif)
I have many of these for all my bikes, lawnmowers & generators and keep them plugged in (with harness plug to battery) constant when equipment is not being used. Have for years without any failures or dead batteries.
Use them for sure.
![Quote](images/misc/quote_icon.png) Originally Posted by ARtraveler
Yes, during the winter shutdown( Spyder) it was on a battery tender when it was in hibernation.
Thanks, I am putting the suggestion out there.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
If you have a true battery maintainer, then why not. If you do not have the correct type maintainer, then skip it.
The correct type maintainer has a mode that desulfates the batteries plates.
![Quote](images/misc/quote_icon.png) Originally Posted by PMK
The problem with that is that many people THINK they have the right type.
![Quote](images/misc/quote_icon.png) Originally Posted by Steve W.
More correctly, many have insisted they have the correct type, and do not. Myself, I no longer even get concerned about what others are using or not regarding battery maintainers. Often here there is a Sheeple mentality, far better to read about what others use, then research and validate yourself for what is best for you. Belt tensioner / dampers are another sheeple topic.
Baaa--Baa--Baa :-)
Battery maintainer
I've got a 2014 RTS SE6 and in the fall, after last ryde, I put the Spyder on a battery maintainer until spring. Last Sunday, 15 April 2020, I went out to start the Spyder, on the first push of the button it popped right off. Hope this helps.
2011 RT-S SE5 Viper Red
2014 RT-S SE6 Cognac
Bajaron sway bar w/ aluminum heims
Custom Design HM Brake light
Custom Design Red front fender lights with turn signals
Lidlox
Corbin arm rests
I have found that the Battery Tender Jr pictured in the above post, works flawlessly. It is also available at Walmart and everyone has one of those near them. Mine was located near the air compressors in our store, not near the car batteries.
Hey Joel your ride looks sharp! Back to topic...
HE>I
I use the Battery Tender JR. 12V 750mA, 1.25A. Can be used for all outdoor vehicles.
Automatically switches from full charge to float charging mode,
Reverse Polarity Protection to ensure user safety-Red & Green lights alternately flash in this condition.
Spark proof,
Correctly Charges and Maintains all flooded AGM,Gel, and sealed maintenance free batteries.
I also have a 2014RTS-SE6 when the spyder goes into winter storage in the fall, it goes on the Battery Tender Jr. then in the spring when spyder comes out of hibernation it also starts right up, and I am ready to ride!
I have been using the above since 2012.
I am just putting this out there.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Spark proof,
Deanna
YUP! I have four of them and counting. Only needed one for the John Deere this winter though. Bikes never were on chargers this year, there was no winter layup.
2020 RTL SE6
![](signaturepics/sigpic10748_5.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by MeudtPG
Use them for sure.
^^^^THIS^^^^ Deanna. I use them on all of my power equipment. They "maintain"...in other words only slowly charge when needed. And yes, if your bike is still gonna sit, you should hook one up. My guess is the dealer had it hooked up during storage
![](signaturepics/sigpic17423_8.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by Mazo EMS2
MazoEMS2, Yes, I do use the Battery Tender Jr. 12V. It maintains a charge/and switches to automatically floats.
Yes, my bike will continue to sit, and I'll hook it up. The dealer did have it hooked up when in storage during the winter months.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
I have had 4 spyders and I stored them in the winter months. I have never used a charger or a maintainer on any of them. They start right up in the spring.
![Quote](images/misc/quote_icon.png) Originally Posted by ndspyderlover
What do you use to keep the battery charged in the winter months?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
I do not use anything . I just start it and ride.
I see you are from North Dakota, so you must get the cold/ and snow in the winter from the great lake?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
We are not near any great lake. I disconnect the battery n the winter.
Ok.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
