Results 1 to 25 of 28
    Member MrBill5491's Avatar
    Jan 2020
    New Mexico
    Default Disabling air compressor
    Okay after an hour searching for this procedure, nothing concrete has come up so here it goes. The compressor on my 2015 RT is always cycling whether someone or ones are on board or off the Spyder. I want to disable the pump and strictly go manual on the pressure for the air bag. How do I go about this? Oh yeah, mine has the leveling system on it. I do love pics.
    MrBill
    Las Cruces, NM
    Got Chile? Red or Green?
    2015 Spyder RT
    1980 Suzuki GS750ET, still scares me!
    Jun 2017
    Hanover Ont Canada
    I just went through the same thing as you on my 2015 RTL I had to disconnect it. It is a bugger to get at I had to take all of the side panels off to see it and to get at it. The plug is on the back side of the compressor there is a black plastic nipple holding it on a plate if you can pull it off of there it makes it a little easier to unplug it. But you have to wiggle your hands up there to get at it. It would be easier if you had a hand of a 12 year old because not a lot of room. Now I am filling the bag manually under the seat. Sorry no pics I hope the helps.
    Jan 2015
    southern WI
    Hmmm, is there a fuse you can pull?
    2016 RTS , Pearl White
    indpls in
    maybe you have a leak so disabling might not be the answer bottle of soapy water on fitting and lines dont forget the bag
    Nov 2018
    Claremore, Ok.
    I thought my compressor was cycling also. But it was the DPS that I was hearing at low speeds. Check yours before tackling the compressor. Try a mechanics stethoscope to listen if you can, or tape a recorder in the area.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jul 2010
    Las Vegas, NV
    The fuse also controls other stuff. Unplug.
    Joe Meyer
    Oct 2014
    Fort Mill, SC
    The easiest way to disable the compressor is to pull the ACS relay. I'm not sure which one it is on your bike. Check the air bag system for a leak first.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Sep 2012
    Stetson, Maine
    On the V-twins there is a relay you can remove. On 2014s and newer i do not know. If you do disable your compressor you will also have to unplug the power to the air release valve. There is alot of good info about this subject at this site. If your air bag is in good shape, all you need to do then is run a hose from shrader valve to air bag. Good luck.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Dec 2009
    West Oz
    Quote Originally Posted by Revalden View Post
    Please tell how you found this and fixed it. Curious.
    Quote Originally Posted by MrBill5491 View Post
    ..... The compressor on my 2015 RT is always cycling whether someone or ones are on board or off the Spyder. I want to disable the pump and strictly go manual on the pressure for the air bag.....
    I'm sorry MrBill, but if your compressor is cycling all the time, then it's almost certainly because you have a leak in the ACS system somewhere & disabling the compressor probably won't let you go manual anyway!!
    That leak or leaks may be in the 'non-return valve'; more likely be in the air bag itself; or most likely be in one or more of the 'push-fit' air line fittings.... You'll need to fix or bypass the leak/s before you can get any sort of working ACS again, even if you do want to go strictly manual!
    Nov 2018
    Claremore, Ok.
    Well, I put a clip-on pressure gauge on the Schrader valve, it read 40psi, went back out next day, still 40psi. then, a few days later I had to start Spydie to check on something, I accidently moved the handlebars and heard the motor in the front end. I haven't had it fixed yet but I'm going to schedule it for diagnostic at our local dealer soon and hope that my Policy will cover it. From what I've gathered from my Service Manual it could bad sensor, or I'll hafta run more air pressure in my front car tires. Otherwise I'll just hafta wait until it goes belly-up and develop more arm strength.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Dec 2009
    West Oz
    Thanks Rev, but it's this comment I was asking about: But it was the DPS that I was hearing at low speeds.
    Clinton, MS
    I thought he did a pretty good job of explaining it.
    Nov 2018
    Claremore, Ok.
    Thanks EdMat. I'm not sure about this but I think the electric motor part is the same as the e-brake motor and I've seen the e-brake assembly for sale around $175.00 for a used/salvage one. If worse comes to worse I will dig into the front end and see if the DPS motor will detach from the rest of the assembly. Maybe someone here could answer this question for me before I go that route.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    in rt 2011 Ltd. there was a software option and there are instructions too on BRP web page to mount the self-adjusting suspension in "no ltd" Spyders. Same option with opposite option.
    the dealer did it for me.
    But if the problem is an air leak you will not be able to maintain the pressure manually. To avoid engine, leaks and air tank problems I deactivated the software option and installed a gas damper with double adjustment. Although the conditions are not "optimal" at any time you can achieve a very good compromise adjustement and you'll know that these parts will not be the problem never again.
    2018 F3 Ltd. , Black/Dark
    Jun 2010
    Las Vegas
    We have disabled the compressor and then we used BUDS to change the programming so that it now thinks the Spyder is not equipped with the compressor.
    Yes, you need tiny hands to disconnect it.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    The DPS motor is not a motor in the traditional sense. It's also integral in the DPS unit along with the torque sensor and steering angle sensor. I don't believe anyone makes a remanufactured DPS which is a clue as to the practicality of repairing them.
    Jun 2010
    Las Vegas
    And they are really expensive!
    2010 RT- 622
    Dec 2009
    West Oz
    Thanks for the clarification Rev.
    Nov 2018
    Claremore, Ok.
    Thanks IMS, now that I'm not half asleep, I remember that the motor for the windshield and the E-brake are the same, Not DPS motor.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Dec 2009
    West Oz
    . Loose Nut Behind Handlebars Thanks for that second clarification Rev
    Jan 2020
    New Mexico
    Yup you can easily hear it hissing on and off, doesn't matter if you are on or off, moving or not. As long as the the engine is running you can hear it doing it's thing. Great just great, sounds like it's going to be a long ass afternoon tracking this down.
    MrBill
    Las Cruces, NM
    2015 Spyder RT
    Jan 2020
    New Mexico
    Dang thing will cycle whether you are moving or not and if you are on or not. As long as the engine runs, you can hear it and hear it a good distance.
    MrBill
    Las Cruces, NM
    2015 Spyder RT
    Oct 2014
    Fort Mill, SC
    MrBill, you have one of two problems. 1. A leak in the bag or system. 2. The compressor has failed. There is a set screw on the crank shaft that backs off. The compressor motor runs but, the piston will not pump air. I have replaced 3 compressors with this problem. One on my bike and two for friends. I have a video on YouTube showing how to install an after market compressor. Go to YouTube and search for Can Am Spyder Compressor. It's about 45 minutes long.
    1998 Honda Valkyrie
    US Navy Veteran
    Aug 2019
    CT
    I need a little help here for my 2014 RT-S. The air damper does not hold air when filled manually and I'm not sure if there is a compressor or if it is running if present.
    I'm going to be replacing the rear shock with an Elka from Lamonster..Do I still need to have the damper operational with the new shock? I saw a review on Lamonster by a guy that just left his air damper disabled after installing the new shock. I don't mind saving $200 -$300 to leave it as is, but don't want to be open to doing damage to that $600 + new shock.
    Anyone out there have any experience with this?
    That's all folks !
    2014 RT-S , This will be the first thing I do for it. Yellow
