Results 1 to 7 of 7
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default 2014 ST Coolant Question
    Hi all my wife’s 2014 ST has a coolant leak I just noticed as I was brining it out of hibernation. It looks to be orange in color I’ve read where only green is mentioned. I’m getting ready to pull the right side panels and check the hoses and get a better look at the coolant tank. My question is what type of orange coolant or can you mix colors. Thanks Michrick
    Hers 2014 ST
    His 2016 RT Limited
    2016 RT Limited , White
    Bossier LoUiSiAna
    DO NOT MIX
    Dilute with water will do & better than risking mixing. & might want to consider replacing stock clamps with regular screw type hose clamps if & while you have tupperware off
    May 2015
    Liverpool, NY
    Thanks Bfromla for the advice. I plan on tackling the Tupperware this week, hopefully no issues.
    Hers 2014 ST
    His 2016 RT Limited
    Mar 2008
    Hesston, PA
    I just changed the coolant this week on 2014 RTS and it had orange coolant and the replacement BRP coolant was also orange...Sold by the quart and expensive...
    May 2015
    Liverpool, NY
    Thanks larryd I plan on calling my local dealer today to see if they are open. If not this project will be put on the back burner for a bit. Be safe
    Hers 2014 ST
    His 2016 RT Limited
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    IMG_0929[1].jpg Orange XPS extended life coolant part number 779150 in the quarts; our 1330 F3T took 4 qts, but your 990 may take less.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    Default Is the coolant proprietary?
    Couldn't the same extended life coolant be bought from an auto parts store a lot cheaper and perhaps easier?
