Results 26 to 50 of 53
Thread: Wear a Mask!
  1. #26
    Northern Kalifornia
    No, they won’t avoid contagion to the rest just because they are wearing a mask, mcalva. The advice from both the National and State Chief Medical Officers out here (and elsewhere) say that if you are wearing a mask, but aren’t yet showing symptoms even though you have the virus and are contagious, you will be constantly fiddling with the mask which puts the contagion on your hands and spreads it just as effectively as those not wearing a mask in the same condition. The mask simply gives YOU a false sense of confidence.
    FINALLY, someone gets it!! Thanks Peteoz.
  2. #27
    Vermont
    Here in Vermont:
    There is a new directive from the Vermont Health Department Friday, and CDC is expected to issue similar guidance soon. A visibly growing number of Vermonters over the past week have started to wear masks or other face coverings when they are out and about.
    The reason for wearing a mask or the facial covering is to protect others around you in case you are in that pre-symptoms infectious phase. Per the governor, I want to be clear, this is not a substitute for staying home and it is not an excuse to mingle with others.
    Sorry off topic!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  3. #28
    Back a long time ago while I was doing some advanced training that including putting on, living in, & taking off the full on Nuclear, Biological, & Chemical Hazard Protective suits & gear with a bunch of other Specialist Military types, in the early stages of that training, before we got on to the really hardcore stuff (some of which was quite gross just to think about even now - so I'm not going there again!) we spent a fair while in basic Hazmat suits while we took a bit of time (days for most, weeks for some) practicing safely getting those 'mouth/nose sanitary napkin' type masks on & off.
    First, we had to learn to put them ON properly.... so the parts they were meant to cover got a fairly good layer of stuff that was sorta like fluro foam shaving cream slathered on them before the mask went on - and when you put the mask ON, any fluro foam escaping meant FAIL - if this was real, you'd be dead! Once we all eventually managed to get the masks on properly without 'killing' ourselves, we then progressed to learning how to take the masks OFF without contaminating ourselves or anyone else.... so for this, the fluro goop went all over the outside of the mask and any fluro foam getting on any part of your hands/face/body during the removal process meant FAIL - if this was for real, you'd be dead!
    The fluro shaving cream stuff was simply used to highlight how bloody easy it is to NOT fit these types of masks properly enough to protect yourself, and then even if you DO manage to do that properly, getting it OFF without contaminating yourself in the process is several orders of magnitude harder! Plus, cos it stung like buggery if it got into anything moist (eyes, nose, mouth... ) it drove home to us that while this type of mask is on and before you get used to wearing it properly, it markedly increases the number of times you touch it with your hands & then touch your face &/or your eyes and doing that JUST ONCE can be the 'once' that's critical for you!!
    But it is your choice &/or that of your government/local authorities really - and given that the infection rates in largely 'mask-wearing' communities & countries doesn't seem to be greatly different than that elsewhere/in 'non mask-wearing communities & countries' (is that cos not too many wear eye protection? ) I guess that it could be reducing the 'volume' of viral exposure you get, possibly meaning a milder infection; and if you are asymptomatic you might still be reducing the 'casual exposure risk' for all those around you; all of which means wearing a mask might just protect others a bit more even if that protection is to your cost in some degree! Still, I'm no expert in this, my training was decades ago and these days my forgettory tends to work better than my memory on some things, so who am I to say &/or listen to about this?! You do what you will/what your govt tells you to do, and I'll do what I will too!
  4. #29
    Aug 2013
    SF Bay Area
    Quote Originally Posted by gom View Post
    You are 100 percent right also I talked to a DR that rides with me ,and he explained that if you do not wear the N95 mask and wear anything else you could catch the virus easier , because it does not filter it and will just **** in it and you will just keep breathing it in. So no mask might be better than anything other than the N95 one
    It's not for your personal protection, its for everybody else's protection. Like coughing into your elbow to prevent others from your cough, a simple double cotton mask does the same thing. If it's comfortable then you won't fiddle with it. Only need to wear if closer than 6'.
    2021 F3 Ltd , Magna Red
  5. #30
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I absollutelly agree with the part you say masks are only a part. I've been speaking about masks only. But I disagrre with the part saying the mask only gives us a false sense of confidence. Unfortunately, my wife was diagnosed with breast cancer and due to chemotherapy we have been in semi-confinement since January. Lately total. Given the immunodeficiency that it causes, it is necessary from the first day to wash hands, keep personal distancies and that I wear a surgical mask to avoid any contagion to her. From the total confinement the difference is that the mask we wear is an N95 III and gloves when we go to the hospital. To remembrer not touch my eyes I wear glasses.
    at worst everything ends up being useless but one thing is an accident and another a suicide.
    2018 F3 Ltd. , Black/Dark
  6. #31
    Feb 2012
    Spring City,Utah
    On the news last night was a segment that the CDC was now recommending that you DO wear a mask whenever you go out in public and it could be any type of mask would help. They also suggested that a couple of layers of paper towels as an effective barrier. YMMV.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  7. #32
    Jan 2010
    usa
    WHO... bunch of dummies... CDC...don't know what they are talking about.... but I have a friend who said... or my neighbor says....
    I don't fear this at all.. if I get it life will go on or it won't... Facts... Having survived GBS I know viruses can really be nasty... My only fear is that I will be a-symptomatic or pre-symptomatic and pass this on to someone who may not have contacted it if I weren't the I, me mode... So screw all those government organizations but take the time to think about those who you care about.... Because for most reality becomes real when it affects them.
    As I said in another post.. the virus doesn't move it's self... we move it... While we are out and about keeping our 6ft distance, please do not forget your "brief relief" for a bio as some of the most filthy places are rest rooms....let's not turn any area into an outdoor bio area. (Drops mic, and steps down off box)
    When the going gets tough...Downshift..
  8. #33
    Harrington, Australia
    Quote Originally Posted by mcalva View Post
    Sorry to hear that, mcalva. Sounds like you are really doing it tough. Hang in there, mate, and here’s hoping the best for you and your wife
    HeliBars Handlebars
    Kenda Kanine rear.
  9. #34
    Quote Originally Posted by billythekidd View Post
    I was looking at the John Hopkins map of Covid-19 cases. If you look at a sparsely populated state like Arkansas you'll see cases noted all over the state. I'm mystified. Have people really been moving around that much and coming close enough to each other to spread the virus even just by touching surfaces? For me it just doesn't make sense for that to be the only transmission method. I wonder if there is some other transmission method working out there the hasn't been discovered yet. If it is being transmitted by human to human interfacing only, then people sure are moving around a lot more than seems logical. Like I say, I'm mystified.
  10. #35
    Florida Swamp
    Trucks deliver everything people use and many of them come from thousands of miles away. Somebody loaded the trucks and somebody has to unload them. The mail, Fed Ex, UPS, gas trucks, grocery trucks, bank trucks full of nasty money, beer trucks, ............ not many really isolated places even in rural areas. It only takes one to spread it to a new area.
    2019 F3-S , Black & Silver
  11. #36
    Quote Originally Posted by Gwolf View Post
    That's at least partly what we are seeing here in Australia now.... Little (growing?) pockets of COVID-19 infection appearing amongst the people working in 'essential services', including those in hospitals, supermarkets, & transport hubs et al. Anywhere people have to handle potentially infected patients, material, or even just goods & services - trucking yards, airports, railway & bus stations, even security guards & supermarket shelf packers!! And all these 'essential workers' may have been infected, remain asymptomatic but contagious, & yet still remain at work for some days BEFORE they actually become sick!! So the virus spreads, because we move it!!
    I think it inevitable that we'll all have some exposure to it before this is all over, that's been the way with virulent virus infections since they started waaay back in the dawn of time!! It's just a matter of containing the spread and reducing the total number of those affected/afflicted at any one time to a level low enough that our treatment & care centres can manage the treatment & case load without causing the collapse of the entire system. And don't for one moment think that if we survive this 'initial exposure' phase without causing said collapse that there won't be a rebound/phase 2 (& maybe phase 3?) as all those who missed out the first time round get infected as soon as we all think the worst is past & relax the controls!! It's almost certainly going to be a long haul to beat this one - that is, IF we ever do 'beat' it, rather than simply learn to accommodate it as we've done with so many other diseases.... the Common Cold, Influenza, Smallpox, and many more!!
    So for now, Practicing Safe Social Distancing and maintaining appropriate Hand Hygiene without repeatedly touching your eyes, nose, & mouth seems to be the best approach we have at this time in order to reduce the rate of COVID-19 spread and to minimise the potential viral load we might be exposed to, so that even if you do catch it, you'll likely only get a mild dose so that your body can safely develop immunity instead of something much worse!
    Altho I gotta admit, all this 'sanitising' and cleaning with antiseptics is rapidly destroying my ryding gear & playing right havoc with my Spyder's paint-work!
  12. #37
    Jan 2010
    usa
    I am really no expert, but when I zoom in on the map you mentioned, most not all are near a road which to me lends to the fact they more than likely they (rurals) had to travel somewhere to get supplies. Transmission is not only person to person direct... One person can blow their nose while running and another person steps in it while running behind them and later takes those shoes off not knowing what is on their hands... touches their face (maybe because they are sweating from running) or what ever and bam... Technically this would still be person to person, but not direct as in someone sneezed on me... Anyway.. back to masks, other than the n95 or better I believe it is trying to help stop the spread. If I sneeze and miss my elbow there may be a possibility of transmission, whereas with even a simple mask most of that would remain with me and not escape.
    Not to lend to any conspiracy type thoughts, but he whole world has for the most part shut down... maybe there is something not being told to us as even the last pandemic H1N1 killed a bunch of people with the CDC estimating that there were over 22 million cases in the US alone... Yes, the death rate is higher for Covid-19.. but it still baffles me as to why the whole world is shutting down.
    I personally like this info better than the John-Hopkins... same info just presented different... https://www.worldometers.info/coronavirus/
  13. #38
    Dec 2015
    Oakley Utah
    ...but it still baffles me as to why the whole world is shutting down.
    I'm curious why you think that?
    2014 RTL Platinum
  14. #39
    Same here, actually. What I like the most about the JH site is the visual presentation. Have you noticed how some of the daily new cases graphs on worldometers for some countries look like they're plateauing and not steadily going down? Especially S Korea. That doesn't bode well in my way of thinking.
  15. #40
    " paper towels " .... on a thread I started the other day .... I explained how a P.T. can be folded and two rubber bands stapled to each end makes a cheap but effective mask ..... Mike
  16. #41
    My first thought when I saw a discussion for the first time about 'flattening the curve' is it looks like the downside of doing that is the epidemic continues on longer, but at the end the casualty rate will be much the same. So which is better, a quick devastating crashing blow to humanity, or a slow painful devastation?
    Maybe all the goods movement is a much greater hazard than has been thought. I agree that is the one common connector to all communities. Officials need to look closer and harder at that.
  17. #42
    And if you think about how they're made you should be able to easily comprehend how and why they are sterile, even though that's not said. My retired veterinarian brother used ordinary paper towels in his vet practice because they are sterile and a whole lot less expensive than "sterile" towels. The pulp is mixed hot, I think it is, and then rolled and dried all by machine and wrapped by machine. There's really no place for bad actors to get into it.
  18. #43
    Jan 2010
    usa
    Because for previous pandemics in my life time anyway, the world did not do this. That is the only reason I wonder that. The CDC estimates that H1N1 killed 150k to almost 600k world wide and we did not have any thing like this and that was just 10 years ago...Some studies estimated that 11 to 21 percent of the global population at the time – or around 700 million to 1.4 billion people (out of a total of 6.8 billion) – contracted the illness. This was more than the number of people infected by the Spanish flu pandemic, but only resulted in about 150,000 to 575,000 fatalities for the 2009 pandemic (I believe the Spanish Flu killed 50million). The Hong Kong flu in 1968 killed over a million... Believe me, I know these viruses are not the same, but my thinking was about people dying since straight up they have said 80% will only experience nothing to mild symptoms.. Anyway...
  19. #44
    Jan 2010
    usa
    My response is not directed at you but your point is right on to what I have been saying. We move the virus.. be it goods shipment or "wind therapy" the possibility of spreading the virus grows anytime there is movement. It is not only about personal infection, it is about containment. As was mentioned I also believe we will all be touched by this at some point or another, but if we can slow the spread it may give the scientists time to develop a vaccine for this. Time will tell, but again as much as I would love to go out (I have a RTL and a Slingshot) I am trying to do my part for our country and try not to be responsible for indirectly causing another's demise.
  20. #45
    Florida Swamp
    Seems obvious watching the state map of what counties have virus infection and how many in my state. I look at the map most every day and it slowly filled in by county all down the east coast first......... following I-95 and A1A. Then it filled in from Tampa to the Georgia Border following right down I-75. Now it filling in the counties across the panhandle following along Interstate 10. If you had all the previous maps and arranged them in chronological order, you would see the spread of the virus following the major Interstate highways. It might skip a rural county if there is no large city or intersection in that county, but otherwise, it is almost exactly following the highways as the virus spreads across the state. People are moving along the highways and goods are moving along the highways. Not really much you could do to stop it. If you stop all the trucks, people will be starving to death in a week.
  21. #46
    Very interesting observation, I say. It would good if both the JH site and worldometer sites had previous map and graphs archived so we could see that progression.
  22. #47
    Maybe I'll get an answer of some worth this week. Our Governor is having a weekly Q&A about the epidemic on Idaho Public Television. I just sent a question for him to the program host asking whether truckers and delivery drivers are being tested. He says he is in regular contact with the Feds, and he's close enough to us ordinary mortals maybe the question will get to the top from here at the bottom!
  23. #48
    Clinton, MS
    I can answer that one. As of now there is NO mandatory testing for truckers. As all thing related to this virus it's subject to change.
  24. #49
    Bossier LoUiSiAna
  25. #50
    Clinton, MS
    Today at work.
