Corona Virus Self Isolation means time to do some work on the spyder!
Corona Virus Self Isolation Day 1 starts tomorrow, as I found out today I'm off for two weeks. Time to do some spring cleaning in the garage and add some goodies to the Comet! First up, changing out the tricled fender blinkers for the new tricled sequential fender blinkers. While I have the fenders off, I will also paint the calipers 1969 Ford Mustang Grabber Blue.
Anyone else doing work on their's during the Great Corona Scare of 2020???
2020 Can Am Spyder RT Limited "The Comet #2"
Baja Ron Sway Bar
Passenger Armrests From Can Am
Wolo Big Bad Max Airhorn
Lamonster Top Cuff W/Ram Ball
Lamonster Power Plate
Tackform Phone Mount
Key Cover from Ebay
Lamonster Mirror Locks
Ultragard Cover from Lamonster
Top Grills from Spyderpops
Garage Door Opener from Spyderpops
3.5mm Extension from Amazon
Lamonster USB Cable Holder & Cable
Foam Grips from Spyderpops
Tricled Strobe Brake Light module
Tricled Bag Lights (replace reflectors)
Tricled Turn/Brake/Run Signals Rear
Tricled Floorboard Lights
Tricled Sequential Run/Turn Fender Lights
Tricled A-Frame Run/Turn Lights
Tricled LED American Flag Mount & Flag
Showchrome American Flag
We are not off work yet. Only no large events and schools closed. Some bank lobby's are closed
Rumor has it that Oklahoma Borders are closed, but if we can get this damned Portland, Oregon rain, drizzle, and general GLOOM to go away, I know of a little known back way into/outta Arkansas' Twisties.![Ohyea](images/smilies/ohyea.gif)
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars ![yikes](images/smilies/22yikes.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by FINFAN3DP
That's a really positive way to look at it!
2014 RTL Platinum
![](signaturepics/sigpic20671_7.gif)
The ones you have on there now are the flashing but not sequential ones, right? What they call Gen 1? Do they work well and if so, are you interested in selling them? I have a 2018 RTL and have thought about these but I'm not prepared to pony up the dough for a new set of the Gen 2s.
These are GREAT. Very bright and eye catching. Our city is closed down also. Putting the back together after installing speedbleeders ( # SB6100 is the correct size )
Lew L
2014 RTS in Circuit Yellow, farkle-ing addiction down to once every few months. ECU FLASH IS GREAT. ![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.ID.MT.NV.OR.SD.UT.WY)
![Quote](images/misc/quote_icon.png) Originally Posted by MONK
MONK,
Yes, i have the originals on it now. Check out the video at: https://youtu.be/Zfre4wuUYmg to see them. They work great! Just the week after I got them installed they came out with the sequential, and I have been thinking about them ever since. Plus, since i have to take the fenders off anyway, to do the calipers, I figured now was a good time to do pull the trigger. Yes, I would be interested in selling them. However, i just got the replacement kit from Tricled today, so I'm not quite sure what you will need on your end to make them work. Once I put them on I will know more. I will be sure to check back with you then.
Baja Ron Sway Bar
Key Cover from Ebay
2 weeks, turned into 4 weeks!!!
My off for two weeks, turned into off for FOUR weeks, so I need some more mods to do! Anyone got a tip on some inexpensive mods? Rumor has it, the four weeks might turn into EIGHT!!!!!
Fin
Baja Ron Sway Bar
Key Cover from Ebay
Spyder and Working from Home
One week work at home so far and more weeks at home to come.
Honey do work before Sypder work. I'm completing the build of a grow room in my garage for
sprouting vegetables, herbs, and holding bulbs. Lights are installed and sheet rock is almost complete.
Ventilation will be staged for early next week.
Next is an oil change and fluid change for the Spyder. Will install speed bleeders ASAP.
Will also do a suspension grease job. Yes, the 2013 STS has 8 grease zerks.
Can't think of any additional needed farkles except maybe new front tires.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
![](https://www.spyderlovers.com/forums/maps/map.png?states=CO.NV.HI.NM.UT.WY.IA.MN.IL.IN.OH.PA.NY.NE.CA.OR.WA.MD.VA.WV.KY.MO.MI.SD)
![Quote](images/misc/quote_icon.png) Originally Posted by Haze
I have never thought of maintenance items as farkles.
My understanding has been:
Fancy
Accessory,
Really
Kool,
Likely
Expensive.
Oil change and magic mirrors here today. Motul 7100/Outlaw filter if interested. Show Chrome plugs from LaMonster. Jury is out on those with me. They seem OK, but had no trouble with OEM either. Time will tell.
The Gov of Illinois has a shelter in place order and all non essential businesses should be closed.
That's a laugh. Nothing has changed, Everything is open, people are out.
Cant fix ignorance. I suspect worse before better.
formerly pman2011
Fin
If you haven't done so yet a good detailing; waxing/polishing Spyder and wheels, applying something to restore your black trim.
When I had my RT I installed a LED strip in the trunk with a switch that connected to a USB outlet in the trunk. A very easy and inexpensive mod that was very useful. I noticed it available from some sellers, https://spyderpops.com/rt-rear-trunk...ork-with-2018/ and https://www.tricledusa.com/product-p...ual-usb-plug-1
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
Lil fun![clap](images/smilies/clap2.gif) ![clap](images/smilies/clap2.gif) ![yes!](images/smilies/pepper2.gif) 2E3D3FB3-DB15-48E8-84BA-2E6E0D88801D.jpgB03D4A20-C526-47C1-AB8B-7E03BA96310E.jpg D7134A2F-1C8D-449A-96AB-105487595668.jpg
Found something to help cope with the restrictions D0ED6D4F-A13B-44CC-9EF9-A1B53BD0B4E1.jpg
Luckily found before thanksgiving was intended as a Christmas gift, but just didn’t happen, mild acquaintance anyway np so mine
RT-S PE#0412
https://www.spyderlovers.com/forums/...6&d=1585193531
Actually they are practicing social distancing times two, or 12 feet
Wonder if BRP is gonna cut even more dealers if they don’t get to meet quotas![don't know](images/smilies/shrug.gif)
Finished my DIY GPS kit.
12v lighter socket under the seat, LaMonster mount, Garmin LM50 with TaoTronics BT transmitter, in a Cellular City waterproof case.
Transmits to my Sena in the helmet.
